Volkswagen Touran 1.6 TDi - the candlelight blinks, emergency mode, max. 2ty of
zgarniacz 38193 10
Why does my 2011 Volkswagen Touran 1.6 TDI go into limp mode with a blinking glow plug light after starting in frost, and how can I fix fault 10117 / P229B?
The most likely cause is a fuel-pressure regulation problem triggered by cold weather and unsuitable fuel: the thread identifies the fault as P229B, “Fuel Pressure Regulation Valve 2 Control Difference / pressure too high,” and suggests the engine may be getting summer fuel or a clogged fuel filter/regulating valve [#16179477] [#16179542] One reply says to use diesel suitable for low temperatures because the regulator cannot handle summer fuel [#16179477] The actual fix reported by the owner was to replace the filters and oil, find the fuel filter heavily dirty, drain/add proper winter diesel (Arctica), then clear the fault; after that the glow plug light stopped flashing and the car drove normally [#16180157] If the fault comes back, another reply recommends cleaning the fuel regulating valve on the high-pressure pump and checking the old fuel filter for any metal filings, since contamination there can point to a wider fuel-system issue [#16183935] The diagnostic tool itself may also be outdated, so VCDS or a newer tester is recommended to read the fault correctly [#16178373] [#16179542]
  • Blinking glow plug light causes limp mode below 2000 rpm
    #1 16178352
    zgarniacz
    Rate: 20
    I have recently owned Touran 1.6 Tdi 105km 2011. Today, after firing in the frost -17, the glow plug indicator blinked. The car has lost its power, it is only accelerating up to 2 thousand revolutions. After re-launching the car the same. After connecting the computer, one error still pops up which after being deleted returns. What can be the cause and how to fix it? Thanks in advance for your help.
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 PH HW: 03L 907 425 C
    Component: 1.6l R4 CR td H43 0874
    Revision: --H43 --- Serial number: 00000000000000
    Coding: 00194036032401080000
    Shop #: WSC 01324 020 00200
    ASAM Dataset: EV_ECM16TDI02103L 003003
    ROD: N / A
    VCID: 7BF387AEF2920AC6CEF-802E
    No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
    1 Fault Found:
    10117 - ROD - Unknown Error Code
    - 00 [237]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 259358 km
    Date: 2062.14.24
    Time: 11:51:25
    Readiness: 0000 0000
  • #2 16178373
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, you have an old version of the program.
    Vcds will help.
  • #3 16178386
    zgarniacz
    Rate: 20
    Vcds will help.
    I just noticed it. And after the code itself (10117) it is impossible to diagnose the error?
    I found something like: 10117 - Fuel Pressure Regulation Valve 2 Control Difference
    P229B 00 [167] - Pressure too High
  • #4 16179477
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    You must add fuel to low temperatures. The regulator can not handle the summer fuel.
  • #5 16179542
  • #6 16180157
    zgarniacz
    Rate: 20
    I think success !!
    I replaced filters and oil in the car, when I changed the fuel filter, I noticed that the filter is very dirty. In addition, I learned at Orlen station in my town that this fuel is up to -10. I still had half of that fuel tank and I added a second half of 25l Arctica. I deleted the error and no controls are flashing and the car flies like new. I hope it will stay so and nothing will happen anymore.
  • #7 16180605
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    And it was not even thank you.
  • #8 16180616
    zgarniacz
    Rate: 20
    I was not calm yet because I did not want to swear, I'll wait a few days and see if the problem comes back, thank you
  • #9 16180795
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    For me there are no corrections, I issue a diagnosis remotely.
  • #10 16183628
    zgarniacz
    Rate: 20
    This morning after firing, the candlelight turned back on again, after extinguishing and re-igniting it disappeared and the car was running fine.
  • Clean the high-pressure pump fuel regulating valve and inspect filings
    #11 16183935
The discussion revolves around a Volkswagen Touran 1.6 TDi experiencing issues after starting in extremely low temperatures (-17°C). The glow plug indicator blinks, and the vehicle loses power, only accelerating up to 2000 RPM. Diagnostic trouble codes indicate a fuel pressure regulation issue (code 10117) and high pressure (P229B). Suggestions include using winter-grade fuel, checking and replacing the fuel filter, and cleaning the fuel pressure regulation valve. After replacing the fuel filter and adding winter fuel, the user reports improved performance, although the glow plug indicator reappeared briefly. Further checks on the fuel system are recommended to ensure no contamination persists.
