Timer for 2kW / 2000W Boiler Heater: Comparing Mechanical & Digital Programmers (Links Provided)
18174 19
Can I use a mechanical or electronic timer/programmer to control a 2000 W boiler heater, and is the stated load rating safe for that use?
Yes, a 2 kW boiler heater can be controlled by these programmers, and users confirmed both the mechanical and electronic types work in practice [#16689017][#16687506] One reply recommends the simpler mechanical version, but others noted the electronic one has a week cycle and usually keeps its settings with a battery during power outages, while the mechanical one has a daily cycle and can lose time after an outage [#16687378][#16687661][#16687725][#16687502] The stated 3600 W / 8 A specification was questioned as inconsistent, with one user saying it is probably meant to be 3600 W / 16 A [#16687786] Another user tested the programmer with the boiler for an hour and reported that it did not even get warm, so it should be safe in that setup [#16689439]
  • #1 16687323
  • #2 16687378
    mawerix123
    Help: 482
    Rate: 951
    marhond73 wrote:
    Are programmers like the links below suitable for a bolero?
    Yes, although I would choose the simpler one.
  • #3 16687446
  • #4 16687502
    mrx2000
    Help: 21
    Rate: 47
    It is also worth noting that the watch will become mechanical when the power goes off (in the morning the spouse may complain about the lack of hot water, and why start this day; P) and the time needs to be corrected, while the electronics usually have maintenance settings, but I would not like that bother and don't think that I favor one :)
    However, if by chance you had this socket on a separate circuit and inserted a control clock on the rail in the switchboard, it would be great.
  • #5 16687506
    Michelson
    Help: 82
    Rate: 305
    I have this mechanical programmer with a 2kW heater for several nice years and it works flawlessly. I recommend it for simple control.
  • #6 16687547
    mrx2000
    Help: 21
    Rate: 47
    I saw someone at least for 2 heating seasons had a 3 kW accumulator stove attached to it and gave advice, but personally for 3 kilos I would not have used it.
  • #7 16687559
    Chupacabra
    Help: 247
    Rate: 868
    mrx2000 wrote:
    It is also worth noting that the watch will be in mechanical condition after a power outage ...
    I studied this topic with my grandmother in the countryside, where there are often power outages. Babinka was upset that the clock was on and the water was cold.
  • #8 16687648
    mawerix123
    Help: 482
    Rate: 951
    marhond73 wrote:
    I understand that by saying the simpler you mean the mechanical one with the knob?
    Yes, I have three at home, two control the aquarium and one for lighting up the Christmas tree.
    mrx2000 wrote:
    It is also worth noting that the watch will be mechanical when the power goes out (in the morning the spouse may complain about the lack of hot water, and why start this day; P)
    It's probably logical that when the clock stops, after the power is back it will be warmed up for the time of power interruption, longer, i.e. if it stops at night for an hour, if it was set to 6 o'clock it will work until 7dm. I see no connection here with hot water because the same will happen without any programmer.
    And it's the programmer's fault :?: I would say that it is too long a power outage or a wrong programmer, what it looks like I described the programmer above.
  • #9 16687661
    Zbych034
    Help: 550
    Rate: 1419
    The electronics will switch on the contacts at a specified time, in addition to having a week cycle. Mechanical on decay shifts time and has a daily cycle. I recommend electronics.
  • #10 16687725
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1322
    I also, in the village of Mama for several years hangs the simplest electronic (about PLN 16 on the allegro) connected to the boiler and works great. Interestingly, the battery still holds in the event of a power outage, and is already a couple of nice years.
  • #11 16687737
  • #12 16687786
    mrx2000
    Help: 21
    Rate: 47
    marhond73 wrote:
    Gentlemen, I know the principle of operation of these devices, I meant more if this device can withstand such a load, although the specification states that the maximum load is 3600W and 8A. And it won't start to melt?
    This is something wrong in this specification since 3600W and 8A, probably 3600W and 16A.
    You already have enough information above.
    This is logical when the current disappears on the switched on pin, and if the pin will be turned off at the time of power failure, it will be logical to switch on the delay by the time of the power failure. As the network usually tinker in the middle of the night, and the boiler turns on usually in the morning is a known effect.
  • #13 16687937
    Chupacabra
    Help: 247
    Rate: 868
    I did not write that it is the programmer's fault, only that you have to watch the time setting after the power failure in this mechanical one. Don't stretch like that.
  • #14 16689010
    mawerix123
    Help: 482
    Rate: 951
    Ot said :D ..... of course there is also correctness in your speech, changed heating time with real time may be unfavorable in some configurations.
    marhond73 wrote:
    this one is electronic and has exact specifications.
    It is suitable for your needs.
  • #16 16689022
    kkas12
    Help: 1077
    Rate: 4332
    I just suggest to remember about the contactor. Unless it is a camera with its own socket.
  • #17 16689102
  • #18 16689111
    kkas12
    Help: 1077
    Rate: 4332
    I wrote:
    If so, the contactor is out of the question.
  • #19 16689439
  • #20 16695896
The discussion revolves around the suitability of mechanical and digital timer programmers for a 2000W boiler heater. Users express preferences for mechanical timers due to their simplicity and reliability, especially in areas prone to power outages, which can disrupt electronic timers. Concerns are raised about the potential for mechanical timers to lose time during power failures, while electronic timers are noted for their programmable features and ability to maintain settings during outages. Users share personal experiences, recommending both types based on their specific needs, with mechanical timers being favored for straightforward applications and electronic timers for more complex scheduling. The conversation also touches on the importance of ensuring that the chosen timer can handle the load of the heater, with specifications indicating a maximum load of 3600W and 8A, which some users question. Ultimately, users conclude that both types can be safe and effective when used correctly.
TL;DR: For a 2 kW boiler, a simple plug‑in timer works; one user reports "works flawlessly" after several years. Choose mechanical for simplicity or electronic for week programs and backup. [Elektroda, Michelson, post #16687506]
Why it matters: A correctly rated timer automates off‑peak heating and prevents daily manual switching for water heaters.
Will a 2 kW boiler heater work with a simple plug‑in timer?
Yes. Users report long‑term success with 2 kW heaters on mechanical plug‑in programmers. One states it “works flawlessly” for simple control. Ensure the timer’s rating meets or exceeds 2 kW. [Elektroda, Michelson, post #16687506]
Mechanical vs electronic timer—what’s the practical difference for boilers?
Mechanical timers are 24‑hour and drift after outages because time shifts with power loss. Electronic timers switch at precise times and support week schedules. Choose electronics if you need weekday/weekend profiles or blackout resilience. [Elektroda, Zbych034, post #16687661]
Will a timer overheat or melt at 2 kW?
Select a unit rated around 16 A / 3600 W for resistive loads. That rating comfortably covers a 2 kW boiler element. Avoid under‑rated models or ambiguous labels. [Elektroda, mrx2000, post #16687786]
What happens to hot‑water timing after a power outage?
With mechanical timers, the clock pauses during outages. Your morning heat window can shift, leaving water cold at the expected time. After power returns, recheck and correct the dial. [Elektroda, Chupacabra, post #16687559]
Do electronic timers keep time during blackouts?
Many electronic plug‑in timers include an internal battery that preserves settings and time. A user reports years of backup performance on a budget model. [Elektroda, Justyniunia, post #16687725]
Is running a 3 kW heater on a plug‑in timer safe?
A user saw a 3 kW storage heater run two seasons on a plug‑in timer. However, they would not personally use it at 3 kW. Treat 3 kW as an edge case and choose a contactor or DIN‑rail solution. [Elektroda, mrx2000, post #16687547]
Should I use a contactor with my timer?
Use a contactor when the timer is not a self‑contained socket unit or when switching higher current circuits. If your device is a plug‑in “camera with its own socket,” a contactor is not needed. [Elektroda, kkas12, post #16689022]
What is a contactor, in simple terms?
A contactor is a heavy‑duty relay controlled by a low‑power signal from the timer. It safely switches higher current to the heater, reducing stress on the timer’s contacts. [Elektroda, kkas12, post #16689022]
Can I mount a timer on a DIN rail in the switchboard?
Yes. If the boiler outlet is on a separate circuit, using a DIN‑rail control clock in the switchboard is a clean, robust approach. [Elektroda, mrx2000, post #16687502]
How do I verify my timer isn’t overheating under load?
Run the boiler for one hour and feel the timer’s body and plug. It should remain only mildly warm. A user test reported no noticeable heating after an hour. [Elektroda, Anonymous, post #16689439]
Which is easier to use day‑to‑day: mechanical or electronic?
For simple on/off windows, mechanical is quick and tactile. For complex schedules, electronic offers precise weekday programming. “Choose the simpler one” if your needs are basic. [Elektroda, mawerix123, post #16687378]
What schedule length do I get with each type?
Mechanical timers typically offer a 24‑hour cycle. Electronic models provide weekly cycles, so weekdays and weekends can differ automatically. [Elektroda, Zbych034, post #16687661]
Will a mechanical timer always recover correctly after a night outage?
No. If power fails while the timer is in the OFF period, the ON time shifts later by the outage duration. Plan for this failure mode. [Elektroda, mrx2000, post #16687786]
Any quick setup steps to start safely?
  1. Confirm the timer rating meets 16 A / 3600 W minimum for resistive loads.
  2. Program a one‑hour ON window and run the boiler.
  3. Check the timer’s temperature; stop if it’s hot to the touch. [Elektroda, Anonymous, post #16689439]
What’s a real‑world verdict on mechanical timers for boilers?
“Works flawlessly” for a 2 kW heater over several years, according to one user. Mechanical units are reliable for simple control windows. [Elektroda, Michelson, post #16687506]
