I am looking for schematics and logic for F&Home Radio - WiHome Configurator
GrzegorzCzajkowski 2493 5
  • #1 17484741
    GrzegorzCzajkowski
    I am looking for people who are familiar with the WiHome Configurator for the F&Home Radio system or who have this system
  • #2 17511505
    GrzegorzCzajkowski
    I heat my house with a KOSPEL 12 kW electric cooker.
    Connection to the building =14kW
    At the moment the hot water is supplied by a thermo, eventually an 18kW instantaneous water heater installed in the bathroom.
    I have created a logic that, by switching on the light in the bathroom, disconnects the cooker releasing the power allocation, this gives the possibility to use the instantaneous water heater. By switching off the light the cooker switches back on. A 'blind' bathroom with no window. I am looking for hints on how to solve the problem of using the same instantaneous water heater in the kitchen. With what to disconnect the cooker
  • #3 17511637
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Search under the term "priority switch"
  • Hysteresis bug suspected in thermostat control
    #4 17518393
    GrzegorzCzajkowski
    Hysteresis is another problem. In the settings of the rh S4Tes AC transmitter I set the value to, say, 5 i.e. by 0.5 degrees. I set a temperature range of 12-23 degrees with increments of 0.5 degrees. Well what I observed. The temperature reading is 21.6, the set temperature is 22.0 at this point my furnace should not be heating. When I set the temperature with the slider starting from 12 and stopping at 22, the cooker does not heat (OK for me), but when I move the pointer on the slider, e.g. to 23, the cooker switches on (also OK here), but when I change the value to 22, the cooker continues to heat and here it is not OK.
    Is this an error on the software side?
    Thanks in advance for your help
  • #5 18169281
    meteorolog
    Help: 12
    Rate: 15
    Task 22.1 should switch off. Because when you have a limit set, e.g. 22, it has to exceed it by the smallest value.
  • #6 18169428
    Rysiek2
    CCTV and Stationary Alarms specialist
    Help: 447
    Rate: 659
    GrzegorzCzajkowski wrote:
    Hysteresis, that's another problem.
    Do you know how hysteresis works, what it's all about?
