Amica EHK2.833TeKDRL - My timer flashes displaying only auto - does not work by
blazo123 15015 2
  • #1 19383467
    blazo123
    Welcome.
    I need a programmer for my Amica EHK2.833TeKDRL oven unfortunately I could not find one anywhere. I even called the manufacturer, they don't even have replacements either.
    The timer flashes I only display auto - the oven does not work because of this. I have of course set the timer nothing helps.
  • Timer relay bypass as workaround
    #2 19383522
    mipix
    Help: 495
    Rate: 1484
    From what I remember, one of the cookers used by this company in the past had such an affliction that without setting the timer, what you write about did not work. The distinctive thing, once the timer was set, was the clearly audible sound of the relay switching on. The timer was used to:
    - Switching the heating off after a preset time.
    - Switching the heating on after a set time.
    - Displaying the time
    If you don't care about the timer and the associated time functions, then get to the relay inside the cooker and skip its function. In total, there is one jumper on the relay output to do. Everything will work.
    Or look for why this relay is not getting the control signal from the programmer.
    A flashing timer could mean that you have enabled the delayed start function.
    Press the key with the "handle " and turn the knob to the left - to reset the time.
    You probably haven't set the time on the timer, just the number of hours until the heating starts.
    I don't have the cooker anymore but I remember that you had to combine to start it. Especially after a power cut in the mains.
  • #3 20961173
    izabelabegier132
    Hello!
    I have the same problem, so I would like to ask if your oven has been repaired and what is broken?
    Greetings,
    Isabella
