[Solved] Philips 32PFH4100/88 Continuous Restart Issue: Firmware Upgrade and U405-MX30LF1G08AA-TI Query
bodzio64 8517 2
  • #1 16695100
    bodzio64
    Help: 10
    Rate: 29
    Hello. Main Chinese 715G6947-M0G-000-004K. As in the subject, the Philips logo and reboot,. First restart with Logo the second without and all over again. What's done. After being brought by the client it displayed the text PHILIPS and restart. I downloaded the firmware from the website and after the upgrade (holding the joystick pressed) the same restarts but with the Philips logo, not the inscription (i.e. the upgrade did). You need a batch of U405- MX30LF1G08AA-TI or a hint of what to cling to.
  • #2 16695136
    mailo
    Help: 82
    Rate: 339
    What do you think will happen if you use the input from another TV?
    Read about CI PLus Key Fail ;)
    Best regards.
  • #3 17065094
    bodzio64
    Help: 10
    Rate: 29
    Subject solved. U405 replaced with original batch, TV works fine.
