  • LTE technology
    LTE - Long Term Evolution (LTE) - a standard for wireless data transmission, which is the successor to third generation systems, developed by the 3GPP consortium. The main objectives of the new standard are to increase the possibilities of mobile telephony by increasing the speed of data transfer, reducing delays, increasing the spectral efficiency of radio links, reducing data transmission costs, and simplifying the architecture.
    Frequency ranges allocated to mobile network operators - Link to UKE website
    Signal parameters on frequencies used by Polish ISPs for 3G/LTE:
    Signal parameters in LTE technology
    RSRP (dBm) - Reference Signal Receive Power - measure of signal strength
    Device readings -> from -140 to -44 dBm
    more than -79dBm [more than RSRP62] - very close to BTS
    from -80dBm to -90dBm [RSRP61 - RSRP51] - good
    from -91 to -100 [RSRP50 - RSRP41] - you need to think about changing the location of the modem / router or buying an antenna
    less than -100 [less than RSRP40] - very bad, practically impossible to work.
    RSRQ (dB) - Reference Signal Received Quality - measure of signal quality
    Indication range - from -19.5dB to -3 dB
    more than -9dB - very good, close to BTS
    from -10dB to -15dB - good
    from -16dB to -20dB - you need to think about changing the location of the modem / router or buying an antenna
    below -20dB - very bad, practically impossible to work.
    SINR (dB) - Signal-to-Interference-plus-noise Ratio - a measure of the quality of the utility signal relative to noise interference
    more than 21dB - very close to BTS
    from 13dB to 20dB - good
    from 0dB to 12dB - you need to think about changing the location of the modem / router or buying an external antenna
    less than 0dB - very bad, practically impossible to work.
    RSSI (dBm) - Received Signal Strength Indicator - auxiliary measure; indicator of the received signal strength, including interference, which translates poorly into the power of the useful signal delivered to the user; higher data transfer activity, higher RSSI
    more than -57dBm
    from -58dBm to -79dBm
    from -80dBm to -96dBm
    less than -96dBm
    Sample signal levels and LTE link parameters
    Signal level and connection quality with built-in antennas - Huaweii router:
    Table of wireless function results with parameters RSSI, RSRP and RSRQ.
    Screenshot of an internet speed test showing a download speed of 41.30 Mbps and upload speed of 26.90 Mbps.
    Test with an external dual panel antenna (two polarizations) - Huaweii router:
    Table showing LTE wireless function status results
    Internet speed test result with download speed of 93.30 Mbps and upload speed of 45.24 Mbps.
    Signal measurements and BTS data
    - NetMonster - universal android application that allows you to read the signal level and other data sent by the BTS in communication with our phone for mobile networks - NetMonster
    Screenshot of the NetMonster app from Google Play displaying signal data visualization.
    - Network Cell Info - is an application for carrying out more advanced measurements. Its indicators inform not only about the quality of the signal, but also about detailed parameters and changes over time. The information is refreshed every second and can also be viewed in graphs. The map will show the approximate location of the transmitter with which the smartphone is currently connected - link
    Network Cell Info Lite & Wifi app page on Google Play with interface screenshots.
    - LTE Watch - PC application for reading signal data from Huaweii routers - link
    Screenshot of the LTE-Anbieter.info website featuring the LTEWatch analysis tool. [/url]
    - HManager - android application that allows you to read the signal parameters from the Huaweii router on your phone - attachment
    Screenshot of the huaCtrl app for managing Huawei routers. [/url]
    • TL-MR6400(EU)_UG_REV5.0.0.pdf (10.79 MB) You must be logged in to download this attachment.
    • b525_istrukcja.pdf (1.38 MB) You must be logged in to download this attachment.
    • huawei_b612_lte_cpe_user_manual.pdf (462.07 KB) You must be logged in to download this attachment.
    • huawei-b715_instrukcja.pdf (2.48 MB) You must be logged in to download this attachment.
    • HUAWEI 4G Router 3 Prime Instrukcja obs_ugi-(B818-263,01,pl).pdf (2.75 MB) You must be logged in to download this attachment.
    • Huawei_Manager_1.2_PL.zip (398.94 KB) You must be logged in to download this attachment.
    • ltewatch.zip (100.9 KB) You must be logged in to download this attachment.
    jimasek
    jimasek wrote 35287 posts with rating 2681, helped 3783 times. Live in city Piaski. Been with us since 2007 year.
