EXCEL: Add Symbol at End of Each Paragraph Within Text Wrap Line, Avoid Splitting Words
amczarnowska 6435 9
How can I automatically append a symbol at the end of each wrapped line in an Excel cell without splitting words?
Use a user-defined function (UDF); the thread indicates that normal Excel formulas and formatting are not enough for automatically wrapped lines, and the problem was ultimately reported as solved this way [#16697857][#16706977] A simple SUBSTITUTE formula like `=SUBST(SUB(A1; "."; "* /"); CHAR(10); "* /"&CHAR(10))` only helps when the text already contains real line breaks (`CHAR(10)`), not when lines are only wrapped visually [#16696437][#16696596] The custom-formatting suggestion also only appends the symbol to the end of the whole cell, not after each paragraph [#16696628][#16696645] Another workaround mentioned was to split the text rigidly into a fixed number of lines with a formula, but that is not the same as following wrap-based paragraphs [#16697563]
  • #1 16696187
    amczarnowska
    I need to add a symbol at the end of each line (paragraph) in the line. I know how to add a symbol to the end of each line, but sometimes it happens that a given line consists of several lines (paragraphs) - separated by the text wrap tool. I will just add that each line can have a maximum of 60 words.
    I tried to make a function that inserts a given character after 60 words, but I don't want a given character to split a word in half.
    Sample text of one line:
    Wash your hands with soap
    After washing, wipe your hands clean
    they dry.
    I want the line to look like this after formatting
    Wash your hands with soap * /
    After washing your hands, wipe your hands so that they are * /
    they are dry * /
    I will be very grateful for your help.
  • #2 16696437
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    = SUBST (SUB (A1; "."; "* /"); CHAR (10); "* /" & CHAR (10))
    Seems so
    but better see the attachment for a sample sheet.
  • #3 16696596
    amczarnowska
    Thank you for the information. Unfortunately, the given formula only works if you manually separate the text by using the shortcut Alt + Enter. Depends the formula would work after using the replace text button. Please see the attached file.
    • Przyklad 1.xlsx (13.64 KB) You must be logged in to download this attachment.
  • #4 16696628
    Prot
    Help: 574
    Rate: 297
    The simplest solution is to give all cells with text custom formatting to
    Code: Ini
    :ok:
    You will get the effect as in the screenshot:
    EXCEL: Add Symbol at End of Each Paragraph Within Text Wrap Line, Avoid Splitting Words2017-09...png (35.05 kB)You must be logged in to download this attachment.
  • #5 16696645
    amczarnowska
    Thank you for the information. Unfortunately, such formatting introduces the given character at the end of the entire line, not at the end of each paragraph (line) in the line ...
  • #6 16697563
    Prot
    Help: 574
    Rate: 297
    You can get a similar effect to the expected by using a formula that will be rigid :cry: divided texts from the cell, e.g. into 5 lines (paragraphs?) - see screenshot
    EXCEL: Add Symbol at End of Each Paragraph Within Text Wrap Line, Avoid Splitting Words2017-09-1..1).png (74.37 kB)You must be logged in to download this attachment.
  • #7 16697587
    JRV
    Help: 805
    Rate: 455
    On the other hand, what practical sense of these "flags" in the text perhaps could be solved in a different way?
  • Need automatic line-break marker insertion for SAP upload
    #8 16697606
    amczarnowska
    It is about proper formatting of the text, which is automatically uploaded to SAP. Excel users enter their own text, which is then automatically uploaded to SAP by clicking a button. The problem is that SAP does not accept a paragraph longer than 60 characters and rejects the text. However, if at the end of each line the mentioned early symbol is added, then SAP treats it as Excel Alt + Enter and elegantly copies everything.
    Currently, in Excel, I have a fixed line width and each user knows that at the end of each line, the symbol must be manually entered. The problem is that it is quite time-consuming ... and that's why I am looking for a solution.
  • #9 16697857
    JRV
    Help: 805
    Rate: 455
    unless a user function (UDF)
    • wrap60.xls (25 KB) You must be logged in to download this attachment.
  • #10 16706977
    amczarnowska
    Cool! Thank you very much! :) Works perfectly :)
The discussion revolves around the challenge of adding a specific symbol at the end of each paragraph within a text wrap line in Excel, without splitting words. The user seeks a solution that accommodates a maximum of 60 words per line, as SAP requires this formatting for text uploads. Various suggestions are made, including using custom formatting and formulas, but these methods either apply the symbol to the entire line or require manual intervention. A user-defined function (UDF) is proposed as a potential solution, which ultimately leads to a successful implementation that meets the user's needs.
