Typing a slash in MS Word (to be even)
donka 60663 10
How can I type a fraction in Microsoft Word so the numerator and denominator are properly placed above and below the slash?
Use Word’s Equation Editor and insert a fraction template instead of typing a plain slash, because it automatically places the numerator above and the denominator below the line [#1292984][#1293196] You can open it via Insert -> Object -> Microsoft Equation 3.0 -> OK, or add the Equation Editor button from Tools -> Customize -> Commands -> Insert [#1293196][#1292984] If you need spacing inside the equation, use the special space symbol with the small triangle at the bottom; repeat it for a larger gap [#8486807] A later tip says you can also press Alt+=, type something like 1/2, then press Space to turn it into an equation [#19462683]
  • #1 1292948
    donka
    How to enter hyphenation in word? I mean, for example: x = --------------- and the numbers were above the slash and below the slash? When it combines with indexes and underlining, it is not parallel :(
  • #2 1292984
    smokuss
    Help: 8
    Use something like EQUAL EDITOR in Word and you will have access to a lot of functions
    To activate it, go to Tools in Word and then Customize-> Commands and Insert and there in Equation Editor and drag the icon to the Taskbar (at the top).
    Unless you have it installed as standard, then it will ask you for an MS Office disc
  • #3 1293165
    donka
    ok i installed equation editor but in it i still can't figure out how to do something to make numbers parallel to the bottom and top of the slash.
  • #4 1293186
    smokuss
    Help: 8
    Well, I tried to do x = x / 1 a moment ago and he did it as well as he scored in a murder
    Play around with the functions a bit because you can. That's what it was put in Word because that's how paranoia came out when writing equations.
    Pzdrv.
  • #5 1293196
    johny_84
    Help: 13
    Hello!
    Actually, you need to:
    Insert -> Object -> Microsoft Equation 3.0 -> OK :)
    And equations at will :)
    Greetings!!!
  • #6 1293275
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    The equation editor is quite specific to use (it's best to use the mouse and the directional arrows). However, you can learn it quickly and create any complex equations (you can insert the next one into each "module", etc.).
    • Typing a slash in MS Word (to be even) Edytor rownan.jpg (16.38 KB) You must be logged in to download this attachment.
  • #7 7476478
    klaf88
    Hi :(
    Could someone make me a pattern and send it to the post office in Word ??? For me it can not be downloaded :(
    Wzk = ?K (uł dash) K: ?D (kr.uł) D
    I will be so grateful if someone wants to :)
    Kasianet23(_at_)wp.pl :|
  • #8 7478057
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    What can not be downloaded? I do not understand.
    I don't understand what the pattern should look like. Write by hand, scan and paste the picture
  • #9 8486710
    konstruktor_123456
    Rate: 101
    Well, the equation editor actually works, but how to enter a formula that has a numerator and a denominator consisting of two words. I mean exactly that spaces are not entered there.
    One two
    aaaaa = -----------
    Four five
    and it should be:
    One two
    aaaaa = -----------
    Four five
  • #10 8486807
    rupcio
    Help: 17
    Rate: 42
    Such a stamp with a triangle at the bottom inserts spaces. If you want a larger space, you can use it several times.
  • #11 19462683
    jacekz123
    A simple matter after all, how do you want to do $$frac{1}{2}$$ then you take ALT = and you write 1/2, then a space, and you have the equation :D
The discussion revolves around how to achieve proper hyphenation and alignment of numbers in Microsoft Word, specifically when using the Equation Editor. Users suggest utilizing the Equation Editor by accessing it through the Insert menu and selecting Microsoft Equation 3.0. Some participants mention the need for precise formatting to ensure that numerators and denominators align correctly, especially when they consist of multiple words. Techniques such as using ALT + = for quick equation entry and adjusting spaces with specific symbols are also discussed. Additionally, there are requests for templates and further clarification on formatting equations.
