Polish Landline Number on Android: Buy, Redirect and Pick Up Calls using Skype or Wificall in Plus
duss 4533 14
Can I buy a Polish landline/VoIP number and receive redirected calls on Android while abroad?
Yes—you can use a Polish VoIP/landline number on Android, but it requires a constant internet connection such as Wi‑Fi or 4G; one reply says Android can handle VoIP natively in the calling settings, and that a VoIP operator like Halonet can provide the number and setup instructions [#16697936] Another option mentioned is Plus/A2Mobile WiFi calling, which lets you talk through the app as if the SIM were in Poland when you have Wi‑Fi coverage [#16703672] If you need calls to your normal mobile number to reach you abroad, the thread also mentions redirecting the GSM number to a VoIP number, with a more expensive fallback being a GSM gateway/switchboard [#16698443] The original poster later reported that Halonet worked for a test number and that WiFi Call from Plus was activated successfully for testing [#16706703]
  • Skype landline number and Plus WiFi calling options
    #1 16697536
    duss
    I need to know if it is possible to buy a Polish landline number that I will be able to pick up in any android application?
    What do I need it for ?:
    - I'm flying in November to the "end of the world - cosmically expensive connections" - I need to turn off my Polish mobile phone and make a redirection from my GSM to my new Polish virtual landline number (e.g. Skype) and if I am abroad, I would be able to receive calls on my android.
    Solution # 1: - Skype, I buy a virtual landline number (fee ~ PLN 80/3) and I redirect that when I have my mobile turned off, I should call a landline, and I pick up a landline in the Skype application.
    The cost of such a solution is about PLN 80/3 months.
    Solution No. 2: - Wificall in Plus - plus tests such applications that if you do not have coverage in the area, you can have their applications on the phone and you normally receive a call via the application while being in the range of Wifi, and without GSM.
  • #2 16697558
    DriverMSG
    Help: 3984
    Rate: 4887
    How do you get connected in Skype? Will you have an internet connection there? If so, all you need is an app on your WhatsApp phone and you can make WIFI calls to other WhatsApp accounts.
  • #4 16697720
    duss
    I need to receive my GSM abroad etc. There I will have a foreign sim with internet.
    Applache viber / whatsapp does not suit me ... because I will not tell the client to call me on viber etc. ;)
  • Android’s built-in VoIP calling app settings
    #5 16697936
    kangyooni
    Help: 14
    Rate: 100
    You don't need an app, VoIP is natively in android in the calling app settings. It's so out of the head, because currently, unfortunately, I use an iPhone. It is possible to set only until mid. outgoing (then you save batteries but cannot be received) and normally both ways. Of course, you must have an active internet connection all the time - good WiFi or 4G. After 3G, forget it. Regarding the configuration - you will find info on the internet. I assume that you can get the number from the VoIP operator. Halonet gives you setup instructions so you can do it.
  • GSM gateway as an alternative to VoIP redirect
    #6 16698443
    przeqpiciel
    Help: 285
    Rate: 238
    I subscribe to the idea with VoIP with four paws, but it will be funny if the place where the author goes will be a VoIP blockade :) I don't know why it should be, but there is a shadow of a chance.
    In addition to the idea of redirecting calls from a mobile to a VoIP number (halonet offers the first number for 1 PLN, each next 20 PLN - per year), there is also an option (very expensive) to obtain a GSM gate, thanks to which the author of the topic could make and receive calls from his cells, and he would miss the halonet.
  • #7 16703672
  • #8 16703828
    przeqpiciel
    Help: 285
    Rate: 238
    An expensive solution, i.e. specifying around 500 net. The author invests once and has it forever. Transferring a number to another network? You can and yes, but what about the penalty for breaking the contract early? What if it is a number that the author does not manage, but only uses?
  • #9 16704543
  • #10 16706648
  • #11 16706703
    duss
    Additional info:
    - my sim is subscribed to plusgsm,
    - so I can manage this card as I want - if that's what you wanted.
    What is currently testing:
    - helonet (I bought 1 phone number for PLN 1 and topped up the account) works ok so far, I got a little pissed off to me 2x blocked the account (because I clicked wrongly payment and blockade good morning ;) - maybe it's good because they protect the safety of users,
    - Wifi call - I spoke to his guardian and he started this service for free - great, because without redirecting, etc. everyone calls me on the phone when I'm outside the GSM network.
    For now, both functions are testing and we will see what I choose ... and maybe with both of them I will jump to the 2nd end of the world, etc.
    As Wificall becomes popular, it will be a great alternative to roaming.
    Yes, I know .... you will say that there are a lot of applications for on-line voice calls, but sometimes there are situations that you have to pick up, and the guest on the 2nd side of the handset does not care that you are sitting on the azure coast under a palm tree with coconut ;)
  • #12 16706787
  • #13 16706906
    duss
    I can check .... why do you want to put your card in the gate?
  • #14 16707231
  • #15 16708119
    Oryginal_DekeR
    Help: 19
    Rate: 23
    ad.1
    Not all versions of Android have native VoIP
    ad.2
    VoIP after 3G works, link stability is more important than its speed
    ad.3
    the first VoIP from the edge, full of free applications with configuration description:
    http://actio.pl/pomoc-techniczna/softphone/
The discussion revolves around acquiring a Polish landline number for use on Android devices, particularly for receiving calls while abroad. Users explore options such as purchasing a virtual landline number through Skype, which costs approximately PLN 80 for three months, and utilizing Wificall services from Plus, which allows calls over WiFi without GSM coverage. Concerns about VoIP connectivity, potential blockages in certain regions, and the feasibility of redirecting calls from a mobile number to a VoIP service are also addressed. Users share experiences with various VoIP providers, including Halonet and A2Mobile, and discuss the implications of using SIM cards in VoIP gateways.
TL;DR: Need a Polish landline on Android while abroad? Halonet’s first number costs 1 PLN/year; “Halonet offers the first number for 1 PLN.” Set call-forwarding to VoIP or use Wi‑Fi Calling to answer on your phone. [Elektroda, przeqpiciel, post #16698443]
Why it matters: This FAQ helps travelers keep their Polish number reachable overseas without costly roaming, using Android VoIP or Wi‑Fi Calling.
Can I buy a Polish landline and pick up calls on Android?
Yes. Options include buying a virtual landline (e.g., Skype) and answering in its Android app, or using Wi‑Fi Calling where available. You can also forward your Polish GSM number to that virtual landline so clients dial a normal Polish number. This approach avoids roaming while you use local data abroad. Cost example: Skype number around 80 PLN for 3 months. [Elektroda, duss, post #16697536]
How do I set up native SIP/VoIP on Android?
Open your Phone app settings and add a SIP account from your VoIP provider. Choose to place outgoing calls via SIP only or enable incoming too. Keep a stable Wi‑Fi or 4G connection for best results. “VoIP is natively in Android in the calling app settings.” 1) Get SIP credentials. 2) Add account in Phone settings. 3) Test inbound and outbound. [Elektroda, kangyooni, post #16697936]
Does WhatsApp or Viber solve this if clients call my mobile number?
No. WhatsApp and Viber require both sides to use the same app. If clients dial your normal number, they will not reach you there. Use call forwarding to a VoIP or landline number instead. The thread author rejected app-only solutions for this reason. [Elektroda, duss, post #16697720]
Will VoIP work over 3G when I travel?
Yes, it can. Stability matters more than raw speed for clear calls. Keep background data light and prioritize steady connectivity to reduce jitter and drops. “VoIP after 3G works, link stability is more important than its speed.” [Elektroda, Oryginal_DekeR, post #16708119]
Is there any risk that VoIP won’t work in my destination?
Yes. Some places may block VoIP traffic, which can prevent registration or calls. Consider a fallback like Wi‑Fi Calling from your Polish operator or a second VoIP provider. This is an edge case, but worth planning for before a long trip. [Elektroda, przeqpiciel, post #16698443]
How much does a Polish VoIP number cost (e.g., Halonet)?
Halonet’s pricing mentioned: first number 1 PLN/year; each additional number 20 PLN/year. You then pay for call credit separately. This makes VoIP numbers a low-cost way to keep your Polish presence abroad compared with roaming. [Elektroda, przeqpiciel, post #16698443]
How do I forward my Polish GSM calls to a VoIP number?
Buy a Polish VoIP landline, then set unconditional or “when unreachable” forwarding on your mobile to that VoIP number. When your SIM is off or out of coverage, calls land on VoIP, which you answer via Android. This preserves your public mobile number. [Elektroda, duss, post #16697536]
How does Plus Wi‑Fi Calling help when I’m outside GSM coverage?
With Wi‑Fi Calling enabled on your Plus line, incoming calls to your Polish mobile reach you over Wi‑Fi without extra forwarding. The thread author tested this and could receive calls while off GSM, using only Wi‑Fi and data. [Elektroda, duss, post #16706703]
Does A2Mobile offer a cheaper Wi‑Fi Calling-like option?
Yes. A2Mobile was cited as a low-cost option that lets you talk over Wi‑Fi as if your SIM were in Poland. This can reduce roaming exposure, provided you have reliable Wi‑Fi access at your location. [Elektroda, 22053, post #16703672]
What is a GSM gateway, and should I use one?
A GSM gateway lets you place/receive mobile calls through hardware connected to your phone system. It avoids VoIP numbers but adds cost and complexity. One estimate quoted about 500 PLN net upfront. This is a one-time investment but not always necessary. [Elektroda, przeqpiciel, post #16703828]
Are there legal or policy issues with GSM gateways?
Yes. Some operators require specific subscriptions for SIMs used in gateways. Users noted operator blocking of certain modules and emphasized compliance. Check your contract terms to avoid service restrictions or blocks. [Elektroda, 22053, post #16706648]
Does every Android phone support native VoIP?
No. Not all Android versions include built-in SIP calling. If yours lacks it, install a reputable softphone app and use your provider’s setup guide. This keeps you flexible across devices and OS builds. [Elektroda, Oryginal_DekeR, post #16708119]
Which softphone apps can I use if my Android lacks SIP?
Use any standards-based SIP softphone that your provider supports. The thread points to softphone guides with free apps and configuration steps. Follow your VoIP operator’s instructions for codecs, registrar, and authentication. [Elektroda, Oryginal_DekeR, post #16708119]
Any real-world gotchas when using Halonet or similar services?
Account security checks can trigger temporary blocks if payments or actions look unusual. The author reported two blocks after wrong payment clicks, which were resolved. Keep documentation handy and follow provider payment steps carefully. [Elektroda, duss, post #16706703]
Do I need 4G or Wi‑Fi for quality calls?
Prefer steady Wi‑Fi or strong 4G. 3G can work, but stability drives call quality more than nominal bandwidth. Minimize competing traffic on your network for fewer dropouts. [Elektroda, Oryginal_DekeR, post #16708119]
What’s the simplest travel setup to stay reachable on my Polish number?
Two straightforward paths: 1) Buy a VoIP landline (e.g., Halonet) and forward your GSM to it; answer via Android. 2) Enable Wi‑Fi Calling on your Polish line and use Wi‑Fi abroad. Both keep clients dialing your usual number. [Elektroda, duss, post #16706703]
