Contacting an English Mobile Number in Poland: Dialing Formats (+44, 044) & Alternatives
Eros 25890 5
  • #1 11362874
    Eros
    Rate: 13
    I have this problem because I need to contact a person who has an English mobile number, but that person is now in Poland. How can I get through to her? I have tried all the ways +44, 044 ...
    Have any ideas ?
  • #2 11362930
    konrdzik
    Help: 9
    Rate: 49
    Try 0044 and then the number usually starts with 7 ........................ that is 00447xxxxxxxxx.
  • #3 11362935
    darek_wp
    Help: 119
    Rate: 193
    It may also be that the person is not roaming actively and cannot be reached by phone.
  • #4 11362951
    Eros
    Rate: 13
    But it's only me, I can't call this person, he calls me normally ...
    Added after 1 [hours] 31 [minutes]:
    Will you help?
  • #5 11365776
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2091
    Eros wrote:
    this person is now in Poland.
    Even when it is in Poland, you call as if you were in England. If she calls you, the easiest way is to call her back on the number that will be displayed to you. There may also be some blocking of outgoing international calls, call BOK and ask if something like that is turned on.
  • #6 11365791
    Eros
    Rate: 13
    I've already solved the problem
    I did this: +44 75 (English tel number)
