Heating Curve 1.2: Theoretical Approach to Reduce Heating Costs by 10% Without Integration
cassana22 15882 8
  • #1 16699395
    cassana22
    My question is purely theoretical. I'm not sure if it's the right bookmark, but let's try.
    I need information, as in an engineering way (because it is possible to calculate mathematically this integral) how to move the curve of the heating curve to reduce the heating costs by a specific%.
    I assume that the field under the curve graph determines the heating costs. Let's say I choose a heating curve of 1.2 and I want to move it so that the heating cost is reduced by 10%. Is there any simple way to do this without resorting to integration?
    Thank you in advance for your response!
    • Heating Curve 1.2: Theoretical Approach to Reduce Heating Costs by 10% Without Integration krzywe-grzewcze-wykres.png (78.23 KB) You must be logged in to download this attachment.
  • #2 16699877
    BUCKS
    Help: 536
    Rate: 1087
    I think you have a bad attitude.
    As for me, the heating curve is not used to reduce heating costs, but to optimize the heating process of your apartment / house.
    If you manage to choose the optimal heating curve suited to the specificity of your home / home and your sense of comfort, this will also result in cost optimization.
    The building needs X energy to warm it up and maintain a certain temperature in the rooms and no heating curve will change this demand.
    The more your heating system is "out of control", the more savings you will get by choosing a heating curve that matches the characteristics of your home / house.
    For this reason, there is no simple type dependency of the Y curve, you will save 10%, because each case should be treated individually.
    Do you want tangible savings then do a thermo-modernization or lower the temperature in the rooms. Only when the first one always remains the question after how many years will be the cost of investment in reduced bills, and at the second if you accept a lower thermal comfort than before.
    For a layman, choosing a heating curve is basically a trial and error method and searching for a golden mean.
  • #3 16699931
    michcior
    Level 30  
    Help: 159
    Rate: 462
    What do you heat?
    Tech, can it be a solid fuel boiler? Carbon?
  • #4 16700250
    cassana22
    As I wrote earlier, the problem is only theoretical, I do not want to change the settings of any existing installation.
    I mean only if there is any dependence or way of calculating that when I want to change the heating costs by a certain percentage (i.e., the area under the curve), how then should I choose a new heating curve in relation to a previously selected one? The only question is whether it can be done in a simple way, or only by integrating, because maybe some engineering trick is missing me.
    And this curve from the textile was supposed to be purely demonstrative, I'm sorry, I could choose one without the signature of the company, so as not to be mislead.
  • #5 16700338
    michcior
    Level 30  
    Help: 159
    Rate: 462
    Theoretically yes, but the assumption that only the outside temperature is taken into the curve causes the result to be very coarse, certainly not on a single percentage. There is a difference between -5 and -5 and 40-50km / h wind. And this curve does not take into account. Unless there is a measurement of wind power and the wind-chill factor is calculated - I do not believe in any such existing installation. And it's not so difficult to calculate only you need an anemometer, there is a simple pattern.
  • #6 16700369
    BUCKS
    Help: 536
    Rate: 1087
    As far as I understand this, you do not believe in a home installation with a sunny weather that additionally takes into account the strength of the wind.
    In which case, what would be the point of making calculations if the weather is variable and the wind strength is never constant?
    I think that you always have to take up some roundings and get over certain costs.
    Below a certain level of costs, you can not go down.
    I understood the author's post that she bears the X costs for heating, and then states that it is too much and wants to reduce these costs by, for example, 10% and now what curve she should choose to obtain these 10% savings.
    For me, this assumption is pointless, because if you manage to set the most optimal heating curve then there is no option to reduce costs without changing the comfort, so it remains to be noted that the heating of a given apartment is associated with such and not other costs .
    In turn, it's probably not for everyone to buy drivers to make nonstop adjustments. At the beginning it is so to know in practice how it works, what are dependencies, how it more or less affects comfort, to determine the most optimal settings possible. But then most of them are expecting the effect of turning on a gas boiler and I am enjoying a warm apartment / home, and I spend my time with my family, hobby, etc.
  • #7 16700618
  • #8 16701728
    gaz4
    Help: 77
    Rate: 2982
    In the Polish climate, reducing the indoor temperature by 1 degree saves about 5% on heating. Of course, this is a certain simplification, but if the rate is around 20 degrees at home + -2 degrees, the dependence of 5% on the 1st level is sufficient to reflect savings. In other words, at +18 degrees, we save 10% on fuel, and at 22 degrees we spend 10% more on heating the house.
  • #9 16701821
The discussion revolves around the theoretical approach to adjusting a heating curve (specifically 1.2) to achieve a 10% reduction in heating costs without altering existing installations. Participants emphasize that the heating curve is primarily for optimizing heating efficiency rather than directly reducing costs. They argue that the energy demand of a building is fixed and that savings can only be realized through proper curve selection tailored to individual home characteristics. Suggestions include reducing indoor temperatures, as a 1-degree decrease can save approximately 5% on heating costs in the Polish climate. However, the complexity of external factors like wind and temperature variations complicates precise calculations. Overall, the consensus is that while theoretical adjustments can be discussed, practical implementation requires a more nuanced understanding of heating dynamics.
