Opel Meriva A 2003 Petrol - Central Locking Controller Location & Troubleshooting Guide
adam.lysy 19953 5
  • #1 16699710
    adam.lysy
    Help: 10
    Rate: 31
    Please tell me where in the Opel Meriva petrol 2003 the central locking controller is? The lock stopped working, the fuses checked, the wires leading to the door were all right. Where to look further?
  • #2 16699775
    piotrek22101
    Help: 695
    Rate: 1421
    As far as my memory is correct, it is in a box with relays in the pit. The wipers must be removed.
  • #3 16699810
    adam.lysy
    Help: 10
    Rate: 31
    Thanks for the hint as to how I choose it, I will confirm. I read errors and:
    Dashboard 177 fuel level sensor - but the indicator works
    MTA 179 signal out of range / power problem
    B0017 passenger airbag firing system high resistance,
    B1485 alternator excitation terminal pin 61 open system
    Errors cannot be deleted, you can ask for suggestions.
    piotrek22101
    Help: 695
    Rate: 1421
    As for B1485, it's either a damaged regulator or a diode in the alternator. A friend exchanged whole and helped. As for the cushion, there may be dirty, damaged contacts under the passenger seat.
  • #5 17617778
    AMAL_KC
    Rate: 51
    Hello, I'll join the topic. I have a question if the central locking works tz. the door closes with the key and does not close with the remote control is where to look for damage, the remote control works tz. LED flashes when pressed, battery replaced. Thank you in advance for your help.
  • #6 17620331
    AMAL_KC
    Rate: 51
    The topic resolved, it turned out that the remote control has been discharged from the control panel after re-coding everything works.
