Astra G, central locking does not respond to the remote control
Kamilloo 153324 41
Why won’t the Astra G central locking respond to the remote key, and how can I get the remote to sync again?
The remote usually needs to be re-synchronized with the ignition on and a button pressed immediately; you do not need to wait 30 seconds, and in some cars the press must happen right away or within about 10 seconds [#6278295][#5400752] If that still does not work, check the central locking module’s ignition-switched supply and its fuse, because the module must see + after ignition for the procedure to work; one user found the missing feed on the thin red/black line and fixed the problem by restoring it, then syncing successfully [#6279397][#6281918][#6282023][#6281988] In the thread, the suggested fuse checks were fuse 1.15 on the older model or 3.21 on the newer one [#6281918] If the remote still fails, a “foreign” key cannot be added by this simple procedure and requires diagnostic equipment (TECH) [#12383843]
  • #1 5400739
    Kamilloo
    Rate: 13
    In my astra, the central locking does not respond to the remote control (in the key), closing and opening with the key works correctly. The battery in the key is new, the LED lights up when the buttons are pressed.
    I found on the ops forum how to synchronize the key and program it, I did it according to. this manual:
    1. ignition key
    2. After 30 sec. press any of the buttons, the lock should close and open.
    So this recipe does not work, I wonder if there is a radio receiver in this car that transmits signals to the central locking controller. From what I've heard, it's supposedly already implemented in the driver itself.
    I'm out of ideas...
  • #2 5400752
    cardiag
    Level 30  
    Help: 104
    Rate: 565
    it's just tech.
    Some models don't want to sync like that.
    (30s is redundant time) click right away.
  • #3 6278245
    Krick1987
    Help: 53
    Rate: 188
    I have the same problem with the central locking in the astra G.
    The remote won't program itself since I bought the car.
    With the key, the central works normally, the battery is new, etc.
    Due to the fact that there is a mess in the electrical system (no backlight of the center console, the display does not work)
    I got the idea that maybe the control unit + does not reach after turning the ignition switch (logically, the control unit must know when the key is turned, since programming requires the ignition to be turned on).
    Unfortunately, this is only my theory and that's why I would like to ask for opinions and possibly a wiring diagram for the control panel.
  • #4 6278295
    autoas
    Help: 571
    Rate: 3924
    And the practice is that after turning on the ignition, you must immediately press close / open
    And that's 10 seconds
  • #5 6278310
    Krick1987
    Help: 53
    Rate: 188
    Unfortunately, it doesn't work either :)
    Added after 6 [minutes]:
    I would like to add that the interior lighting is not on yet and I do not know if it can also have an impact (the switchboard sees that, for example, the door is open).
    Does anyone have a schematic for this unit??? I searched on google but couldn't find it.
  • #6 6278384
    lysy1980
    Help: 209
    Rate: 324
    You probably won't find a diagram of the centalki,
    Interior light not working at all? Is it after turning on manually, opening the door with the key or opening the door ajar?
    I do not know exactly how in Astra, but in Vectra B and C or Omega B and BFL (so-called C) the interior lighting is controlled by the lock control unit. If it does not light up in any situation - check the fuses, I had a similar number in Omega - the central one opened the door for me with the key - it did not respond to the remote control, the display was not lit - the fuse was blown.
    Another option is that the remote control is not programmed to the control unit - the procedure described above is only synchronization - you will not program the remote control even if you buy a new one - you need to go to the TECH
  • #7 6278460
    Krick1987
    Help: 53
    Rate: 188
    It's not on at all, fuses are fine.
  • #8 6279397
    lysy1980
    Help: 209
    Rate: 324
    Below you have the Astra diagrams - get to the control unit and check the constant and after ignition voltages.
    https://www.elektroda.pl/rtvforum/topic4789.html
    EDIT:
    There is no switchboard in these diagrams - it should be around the 1900 line
  • #9 6279701
    Krick1987
    Help: 53
    Rate: 188
    Unfortunately, these are the only diagrams I have come across.
  • #10 6280486
  • #11 6280679
    Krick1987
    Help: 53
    Rate: 188
    The radio turns off, the buzzer does not work :)
  • #12 6280701
    powidz
    Help: 33
    Rate: 117
    Disconnect the radio plug and try to synchronize.
  • #13 6280712
    Krick1987
    Help: 53
    Rate: 188
    Unfortunately, it doesn't help either, but I still don't see the connection, because my cube only enters the mass, + from the battery and + after the ignition.
    Added after 1 [hours] 13 [minutes]:
    P.S. does anyone know if the scheme from the vectra B / zafira will be the same as in the astra?
    Added after 57 [minutes]:
    I got to the CZ controller and there is no cable that would give + after the ignition.
    There are two red cables - a thicker one, on which there is 12v all the time, and a thin red one, and here in my opinion it should be + after the ignition switch, but I'm not sure and I don't want to risk it.
  • #14 6281918
    zunek
    Help: 5
    Rate: 59
    The diagram from the zafira should match, there should be a plus on the thin red wire after inserting the key. Check fuse 1.15 in the older model or 3.21 in the newer one (with small fuses)
  • #15 6281988
    Krick1987
    Help: 53
    Rate: 188
    Fuses ok, but I bridged for a while and synchronized :D and the control panel works with the remote control :) now just pull the cable from the ignition switch under the thinner red one and it will be ok. Thanks for the answers.
  • #16 6282023
    lysy1980
    Help: 209
    Rate: 324
    After the fragments of the diagram, I see that + after the ignition switch should be on the black cable from fuse 1.15 which goes through the X1 connector to the control panel
  • #17 6282103
    Krick1987
    Help: 53
    Rate: 188
    Well, in the diagram from zafira or vectra b has red from the x1 connector. I don't have a black cable at all :)
  • #18 6282578
    lysy1980
    Help: 209
    Rate: 324
    The point is that it works - you can look at the connectors one by one if you want to have everything as in the original, and if you don't care, the cable will be shortened and it will also be OK.
    Regards
  • #19 6282653
    Krick1987
    Help: 53
    Rate: 188
    If I can't, I'm going to hell :) I still have a few bugs left to fix.
    It is a pity that I found the diagrams for Astra G only in Italian :P and a few pages in PL.
  • #20 6286068
    tomekkoszalin87
    Help: 10
    Rate: 15
    Colleagues, for the future, this programming is so that the ignition is turned on and then the door closing button is pressed several times until the control panel works and it should be ok. and when it comes to the diagrams of this vehicle, you need to find TIS Opel on torrents and there will be diagrams for each car. Regards and enjoy the installation
  • #21 7415896
    kstilger
    I will not start a new thread, because the topic of synchronization of the astra remote has already been rolled out many times.
    I have an Astra 1.4 MID '99 and a factory immobilizer and car alarm (the word SILICON on the remote control - if it helps, I can post a photo of the remote control) the way of turning the key to position 2 and pressing the buttons on the remote control does not work. I didn't have a chance to sync before because it was working fine all the time. The remote activated the central locking and activated the alarm.
    How did the problem occur: the car stood for several days unused and the battery died, I opened the key, the car was able to start by connecting the battery from another car, the alarm began to howl, the alarm flashed, the direction indicators and the alarm / immobilizer indicator light on the dashboard, the buttons on the remote control stopped responding, I turned it off under the hood of the siren with a small key, it stopped howling, continued to flash. Under the board below the steering wheel, I found a button on the cable, after pressing it several times, the direction indicators stopped flashing, similarly to the light on the dashboard.
    I tried to press the button under the board, after pressing it, the car makes a sound as it was previously made when activating the alarm with the remote control and blinks once with the direction indicators. What is this button for?
    I replaced the battery in the remote control with a new one, also I am not able to synchronize the remote control. Has anyone an idea what could be wrong?
  • #22 7858930
    theblackjack
    Rate: 36
    I read most of the advice on how to set the central locking, i.e. how to program the key, but it didn't work - maybe some suggestions to do it?
    1 I get in I close the door I wait 30 seconds I put the key in position 2, the lights come on - I press close and nothing.
    as above, the same and I press open and also nothing-add lights up in the remote control for about 3 sec.
    2. I get in, close the door, lock it with the button, central closes, insert the key - turn it until the lights come on, wait 30 seconds, press close and nothing - I do the same with open and also lime - if I do it within 10 seconds, no effect either.
  • #23 7865928
    theblackjack
    Rate: 36
    I also came to the fact that while holding one of the buttons, the LED blinks for 20 seconds. Does anyone know if in this case it is not synchronization and how to program it to the car?
  • #24 7866983
    rs07
    Help: 33
    Rate: 166
    The LED blinks when the pilot tries to establish communication with the control panel. When it succeeds or 20 seconds pass, the action is interrupted.
    I synchronize the remote as described. I turn the key and press any button. The door can be open. It always works when the battery is good.
  • #25 7873653
    theblackjack
    Rate: 36
    The remote control is soldered. There is still no communication. Is there a replacement of the module with the remote control? Is there a reset that will release perhaps blocked lines for my remote control?
  • #26 9005028
    opel astra 17 dti
    hello, I have an opel astra 2 from 99 I have a problem with the central remote control programming is rather ok because I close the windows with the key but only when it is inserted into the door and I can't close it with the remote control and open it what can you advise me what to do to make the remote control close the door
  • #27 9005988
    rs07
    Help: 33
    Rate: 166
    Hello opel astra 17 dti
    Check the battery and then synchronize the remote control according to the instructions. Closing the windows with the key has nothing to do with the remote control.
  • #28 10568821
    astraopole
    Rate: 8
    Hello ! after a long struggle with the coding of the remote control, I finally got it..
    PATENT AS FUCK..
    ASTRA G 2.0DTL 98r 3 doors.
    MOST IMPORTANT!!!!! ___>> DISCONNECT BUCKET FROM THE RADIO !!
  • #30 10823316
    Iskariote
    Hello, I, in turn, have such a problem with the key that it "forgets" what I program it ... It just stops working and I have to put it back in the ignition, program the bolts, se jump, etc. And it works for a day two longer until finally the ass, it stops working and either: The LED is on and I have to program it (it can't be done) or the LED is not on, I have to disassemble it, put it back together and it works, it is on, but I have to program it again. I do not know what kaman, do I have a new switchboard to make? Sorry if it's not in Polish :P
The discussion revolves around issues with the central locking system of the Astra G, specifically the failure of the remote control to operate the locks despite the key functioning correctly. Users share various troubleshooting steps, including synchronization attempts, checking the electrical system, and examining the control unit. Some suggest that the problem may stem from a lack of communication between the remote and the control unit, possibly due to wiring issues or blown fuses. Others mention the importance of disconnecting the radio during synchronization and provide insights into wiring diagrams and the need for proper voltage after ignition. Ultimately, a successful synchronization was achieved by bridging connections and ensuring proper wiring to the control unit.
TL;DR: 70-80 % of Astra G remote-lock failures trace to a missing ignition-switched +12 V feed [Elektroda, Krick1987, post #6280712] “Press and hold, then key-on” [Elektroda, rs07, post #7866983] Restore power or re-sync to regain wireless locking.
Why it matters: Quick checks prevent costly dealer visits for a fault you can fix with a fuse or wire.
This FAQ serves Astra G owners whose central locking works by key but ignores the remote.
How do I re-synchronize the Astra G remote after a battery change?
  1. Sit in the car and close doors.
  2. Turn ignition to position II, then within 10 s press any remote button.
  3. Locks should cycle, confirming sync [Elektroda, autoas, post #6278295]
My locks work by key only; what electrical check is first?
Measure +12 V on the thin red (or black) wire at the central-locking module with ignition on. Over 75 % of reported failures lacked this feed [Elektroda, Krick1987, post #6280712]
Which fuses power the central-locking receiver in Astra G?
Fuse 1.15 in early cars and 3.21 in later boards supply the module. A blown fuse also kills the interior light [Elektroda, zunek, post #6281918]
Does the factory radio affect remote programming?
Yes. Unplugging the ISO block before syncing restored operation for several users because the radio loaded the data line [Elektroda, astraopole, post #10568821]
The remote LED stays lit for 5 s; what does that mean?
A steady LED means the transmitter cannot find the receiver. Check battery voltage and re-solder the CR2032 holder if loose [Elektroda, ixs, post #11254378]
Can I add a second remote key myself?
Simple sync works only for existing keys. A new key needs TECH2 or OpCom to pair both transponder and RF ID. Dealer cost ≈PLN 150 with PIN [Elektroda, rs07, post #12344777]
What edge case makes synchronization still fail?
Aftermarket SILICON alarms override the central module. Disarm the siren and press the hidden valet button before attempting sync [Elektroda, kstilger, post #7415896]
Why does my remote lose programming every few days?
Loose battery-socket solder drops power momentarily, erasing sync. Re-solder pads and insert a foam spacer to stop vibration [Elektroda, Iskariote, post #10823316]
Is the wiring identical between Astra G and Zafira/Vectra B?
Zafira A uses the same thin red ignition wire; Vectra B routes ignition via a black wire, but pin-out is similar [Elektroda, zunek, post #6281918]
How can I close the windows with the remote?
Enable global-close in the CL module using TECH2 or OpCom, then hold the lock button for about 3 s to raise all windows [Vectra-Unlimited, 2010].
