Electrolux ESL65070R - Error 02 - cleaning the hydrostat chamber
bowler 21732 15
Where is the hydrostat chamber on an Electrolux ESL65070R, and how do I clean it to fix error 02?
The part to clean is the hose/chamber between the bowl and the hydrostat on the right side of the dishwasher; disconnect that tube and flush it with hot or boiling water and a syringe [#16707244][#17360521] One user found the tube looked clean at first, but the blockage only cleared after pouring boiling water through the bowl and repeatedly injecting boiling water with a syringe until the flow became full stream [#16734864] The hydrostat itself is not described as something to disassemble and clean; if it is defective, it should be replaced [#17357679]
  • #1 16699799
    bowler
    Rate: 48
    Known and liked error 02 and similarly I had 2 years ago. Then the dishwasher was under warranty, a service technician arrived, entered the cleaning of the hydrostat chamber and actually helped. Maybe this time will help. Where is this chamber located and how to clean it? I took off the front cover (photos below). Generally, the symptoms are that after pumping out water, it doesn't charge. I checked the strainer at the solenoid valve, and the solenoid valve not yet.
    Electrolux ESL65070R - Error 02 - cleaning the hydrostat chamberIMG_201709...202307.jpg (2.57 MB)You must be logged in to download this attachment. Electrolux ESL65070R - Error 02 - cleaning the hydrostat chamberIMG_201709...202300.jpg (2.71 MB)You must be logged in to download this attachment.
  • #2 16699935
    krakarak
    Help: 681
    Rate: 1846
    Visible in the pictures, is the bottom of the dishwasher water, water residues or black liniment?
  • #3 16699951
    bowler
    Rate: 48
    A liniment in the meaning of something that was "painted" in the factory? I would describe it more like a water residue. She was apparently dry. I don't know if now or before the previous failure. Sometimes the error popped up, the dishwasher stood up 5-7 days and started moving :)
    krakarak
    Help: 681
    Rate: 1846
    You have read and verified: link and link ?
  • #5 16700049
    bowler
    Rate: 48
    I read earlier, based on the assumption that solutions are given for advanced service technicians. Once again, I read the topics slowly, hooking up for cleaning :arrow: link and maybe I'll take up the fight. For now, I cleaned this water purity sensor as someone called it (the red one) and as much as I could get inside with my finger. The question is whether such cleaning of this container is sufficient or whether to remove this container.
    I wanted to do this dishwasher cleaning procedure, but I don't know what the bowl and filter are. Do you also need to start calibration after cleaning the purity sensor? Should the hose in the photo be detached?
  • #6 16707158
    bowler
    Rate: 48
    Is the dishwasher cleaning process about unplugging this tube? Does this hose connect the bowl with the hydrostat (on the right side of the dishwasher)?
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3362
    Yes
    bowler wrote:
    Does this hose connect the bowl with the hydrostat?
    Yes.
  • #8 16734864
    bowler
    Rate: 48
    I took out the tube for washing. It turned out clean inside. I connected it from the side of the bowl. I injected water several times with the syringe. It didn't work. I wanted to give up, but I gave it one last chance. I poured water into the bowl so that it drips off the tube into a container. Water was dripping but muddy. I poured boiling water twice. I injected boiling water several times with a syringe through the tube and at some point it seemed to unplug. The water went full stream. I don't even know if there was anything there. Taken 5-6 to wash and so far everything is flying :D
    Thanks a lot :)
  • #9 17327310
    bowler
    Rate: 48
    Welcome back,
    is it possible that somehow I turned off the sound signals in the dishwasher or did this function fail?
    peter falk
    Help: 1158
    Rate: 3362
    Do you like German, try it :)
  • #11 17327962
    bowler
    Rate: 48
    Thanks a lot. I don't know German, but I have understood pictorial images. I set something up. We will see if there will be an effect :)
  • #12 17357398
    bowler
    Rate: 48
    Nine months have passed and the replay of the entertainment. Every 2-3 washes turned off, but re-enabling helped. By the time. Now as in October, that is, he is constantly trying to pump out water that is not there and throws error "2". Just as I recently cleaned the tube with the bowl. They were messy and I thought it would help. Unfortunately, this time could not be done. Is this hydrostat also somehow cleaned? What is the work of this hydrostat?
  • #13 17357679
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Hydrostat, once it is to be replaced, is not undressed.
  • #14 17358614
    bowler
    Rate: 48
    I understand that this is the hydrostat? How does it work?
  • #15 17360521
    peter falk
    Help: 1158
    Rate: 3362
    You didn't clean well. Hot water and a syringe.
    This is the new set. You can buy and mount it
    Do not search the rules of operation because you will get tired.
  • Heater works, sensors replaced, relays to check
    #16 21691385
    foxlis
    I have exactly the same symptoms - fast program: the heater heats, the others do not. Sometimes even on the fast one it doesn't heat.
    The dishwasher is 13 years old.
    Probably on the fast program it doesn't take sensor readings into account (compared to other programs) and therefore turns on the heater immediately as you start the program.
    I set about diagnosing.
    - heater works - 28 Ω
    - turbidity sensor, temp sensor I replaced with a new one, but nothing changed
    - hydrostat I checked and blew in the line, but I will check again
    To check:
    - tacho coil
    - relays in the control module
The discussion concerns an Electrolux dishwasher with error 02, where the machine pumps out water but then does not fill. The suggested repair path is cleaning the hydrostat chamber and the connected tube/bowl assembly, which had previously restored operation under warranty. The user identifies the water turbidity sensor, asks whether the chamber must be removed, and confirms that the hose between the bowl and hydrostat is part of the cleaning path. After removing the tube and flushing it with a syringe, the user finds muddy water in the bowl side and restores flow by repeatedly injecting boiling water, after which the dishwasher works again. Later messages mention recurring error 2, the hydrostat, and a separate issue with sound signals and program behavior.
TL;DR: Error 02 on Electrolux ESL65070R often traces to a clogged hydrostat hose/chamber; one user verified “heater works – 28 Ω.” “Heater works – 28 Ω.” [Elektroda, foxlis, post #21691385]
Why it matters: This FAQ helps DIYers restore fill/heating by cleaning the hydrostat path or replacing the set if needed.
What does Error 02 mean on the ESL65070R?
It indicates the control thinks the tub hasn’t filled, so it keeps draining and aborts. Users report constant pump‑out with no water intake before Error 2. This points to a pressure/level sensing issue, usually the hydrostat path clogging, not the inlet valve. [Elektroda, bowler, post #17357398]
Where is the hydrostat chamber and hose?
The hydrostat assembly sits on the right side. A small hose links it to the bottom bowl (sump). Cleaning involves unplugging that hose, as confirmed by service replies in the thread. [Elektroda, peter falk, post #16707244]
How do I clean the hydrostat hose and chamber?
Three steps: 1. Unplug the bowl‑to‑hydrostat hose. 2. Flush the path using hot water with a syringe until flow is clear. 3. Refit and test a short cycle. Experts summarize it as: “Hot water and a syringe.” [Elektroda, peter falk, post #17360521]
What if the hose looks clean but Error 02 persists?
Debris can sit in the bowl port or chamber. Pour boiling water into the bowl and let it drain through the hose into a container, repeating until a full stream appears. One user saw muddy water, then normal flow, and five to six good washes. [Elektroda, bowler, post #16734864]
Do I need to calibrate sensors after cleaning?
In this thread, the practical fix was only mechanical cleaning. No calibration steps were required or reported to solve Error 02 for these cases. [Elektroda, bowler, post #16734864]
What is the hydrostat on this dishwasher?
It’s the pressure‑sensing unit that reads water level via the small hose from the bowl. In the ESL65070R, helpers identify it on the right side, connected by that single hose. [Elektroda, peter falk, post #16707244]
Can the hydrostat be disassembled and cleaned internally?
No. A pro in the thread states the hydrostat is not meant to be opened. If the path is clear and errors persist, replace the hydrostat set. [Elektroda, mrice, post #17357679]
My dishwasher sometimes recovered after sitting for days—why?
Moisture and debris can shift as the machine dries. One user noted errors stopped after the dishwasher sat 5–7 days, then returned. That pattern fits a partial clog in the sensing path. [Elektroda, bowler, post #16699951]
How can I quickly confirm the hose is the issue?
Disconnect the bowl‑to‑hydrostat hose and push hot water through with a syringe. If resistance drops and flow becomes steady, you’ve cleared the blockage, a known successful field check. [Elektroda, peter falk, post #17360521]
When should I replace parts instead of cleaning?
If repeated flushes don’t restore normal filling or Error 02 returns quickly, replace the hydrostat set. The thread’s expert explicitly recommends replacement when cleaning won’t hold. [Elektroda, peter falk, post #17360521]
What is the turbidity (water purity) sensor and should I clean it?
It’s the “red” sensor in the sump that reads water clarity. A user cleaned it by hand, but Error 02 still required hydrostat‑path cleaning. It’s secondary to the level issue here. [Elektroda, bowler, post #16700049]
My heater tests 28 Ω—does that rule out heating faults?
A participant measured “heater works – 28 Ω.” That confirmed heating hardware on fast cycles, while fill/level issues blocked heating on others. Use 28 Ω as a sanity check, not the sole diagnostic. [Elektroda, foxlis, post #21691385]
What’s a tacho coil in this context?
It’s the motor speed feedback coil. One user planned to check it only after verifying sensors, relays, and the hydrostat path. Prioritize clearing Error 02 first. [Elektroda, foxlis, post #21691385]
Why does fast program heat but others don’t?
A user observed fast mode heating while others didn’t, suggesting program logic depends on sensor confirmations. If level sensing fails, the controller may inhibit heating. Fix the hydrostat path first. [Elektroda, foxlis, post #21691385]
Edge case: the hose is clear but it still drains—what next?
The chamber port can clog while the hose stays clear. Boiling‑water pours from the bowl side freed a hidden blockage and restored full stream in the reported case. [Elektroda, bowler, post #16734864]
Can I mute or restore the dishwasher’s beeps?
Yes. The thread shows a control screen indicating audio settings; the original poster adjusted them using the pictorial cues despite language differences. [Elektroda, bowler, post #17327962]
