Peugeot 407: Rear View Camera on RT3 Radio - Black & White, Shifted Image Issues & Solutions
Deamian 12888 2
  • #1 16701755
    Deamian
    Hello. I wanted to retrofit my toy car a little. I bought a camera and converted the display according to the instructions in the attachment. The image from the camera starts after throwing back but unfortunately it is black and white and shifted by about 1 cm. Maybe here is someone able to solve this problem ?? From what I have read and I have already searched a lot of the internet, it is not just me that is tired of it. What is worth trying ?? I suspected the power supply but connected the camera to the power supply under 230v and the same. It is possible to turn on the video source selection in the menu by radio and it is fine there. Something is missing in some models or something else is needed: /
    • Peugeot 407 kamera cofania.pdf (1.76 MB) You must be logged in to download this attachment.
  • #2 16701940
    mateklos
    Help: 50
    Rate: 189
    Hello, see if the settings are suitable for the type of PAL / NTSC camera.
  • #3 16702111
    Deamian
    It's fine in the settings. When I start the camera by choosing through the menu image is good. Only when it is to start itself by engaging reverse gear (i.e. pin 11 cubes on pin 6 of the tape) is bad. So it's definitely not the camera's fault. In addition, I connected the second that behaves the same. If necessary, I can record a video if it is not clear what I write.
    And of course there is a mistake in this picture. 11 pin is a video input
    The problem is exactly like in this video:
    http://autocarvideo.site/watch/rt3-rear-camera-problem=GJ_jwu50CHM=w.html
