Connect Samsung Ace 4 to Windows XP Computer: WiFi USB Card, Router Mode & Network Address Issues
monmar1 10590 8
  • XP likely lacks DHCP support for phone tethering
    #1 16702966
    monmar1
    Rate: 14
    I have a desktop computer at work with WINDOWS XP system without internet access. I wanted to use the package I have on my phone (Samsung Ace 4 in the PLUS GSM network) and bought a wifi USB card for my computer. After installing the wifi card, I set the phone in "router" mode but I have no connection - the message "searching for a network address" appears on the bar in the computer. The computer sees my phone as a router and everything looks OK. Earlier I tried to access the net via cable but the situation was identical.
    Please help.
  • #2 16703071
    qs300
    Help: 242
    Rate: 362
    After enabling internet sharing on your phone, you didn't forget to turn on cellular data in your phone to have internet?
  • #3 16703091
    jimasek
    Help: 3783
    Rate: 2682
    The question is, does old windows support encoding of the wireless network that is set on the phone? Windows XP has SP2?
  • #4 16703109
    paszczakq
    Help: 48
    Rate: 204
    An incorrectly entered password also has such an effect. Try without a password.
  • #5 16703122
    jimasek
    Help: 3783
    Rate: 2682
    I assume that the author of the thread did everything correctly when configuring the connection. Well, of course it can always turn out differently. Let's wait for the interested party in this topic.
  • #6 16703312
    monmar1
    Rate: 14
    Data transfer enabled, password correct, windows XP has SP3. Ports set to car but zero everywhere.
  • #7 16703505
    bogiebog
    Help: 2569
    Rate: 1530
    Run safe mode + network support and try over the cable again.
  • #8 16704081
    monmar1
    Rate: 14
    You can blatantly - I'm not an IT specialist.
  • #9 16710779
    monmar1
    Rate: 14
    CASE SOLVED - you had to change the settings in WINDOWS "Services".
    I don't know what exactly because an IT colleague did it.
The discussion revolves around connecting a Samsung Ace 4 smartphone to a Windows XP desktop computer using a WiFi USB card. The user reports issues with establishing a connection, receiving a "searching for a network address" message despite the phone being recognized as a router. Responses suggest checking if cellular data is enabled on the phone, ensuring compatibility of the wireless network encoding with Windows XP, and verifying the correctness of the password. The user confirms that data transfer is enabled, the password is correct, and Windows XP is updated to SP3. A solution was eventually found by adjusting settings in Windows "Services," though the specific changes were made by an IT colleague.
