Mercedes W203 2.0 comp 02r. - P0410 fault, secondary air circuit, operation
bolekf2 19440 3
  • #1 16424059
    bolekf2
    Rate: 258
    Hello, I am suffering from the fault P0410 in the car as from the topic.
    After several dozen km after erasing the fault, it appears again, it is the error P0410.
    I marked the electric valve controlling the mechanical valve with the arrow. I wanted to ask when, the valve should overpress the negative pressure on the mechanical element? On a cold or warm engine? Or maybe in other conditions?
    Possibly, what could you check if it comes to this recurring mistake?
  • #3 16439017
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Here you have something else:
  • #4 20342411
    msztula
    Help: 6
    Rate: 66
    Has the problem been solved I have the same problem?
