The blower knob does not work from the blower Mercedes A170 2001
driwer78 8628 5
  • #1 16879043
    driwer78
    Rate: 12
    I am not working the fanning knob on the Mercedes A-class again and again. If I put the tester to the fuse and the plus on the battery, it is the voltage, as if the mass was on the fuse. How does the fan work, then the plus appears on the fuse. Will it be the fault of the cube in the ignition switch?
  • #2 16895652
    pompa59
    Help: 13
    Rate: 67
    Replace the fuse. If it still does not work, check the blower itself, [supply power directly from the battery] Check: switch, resistor and fuse in it. However, when the blower is completely dead, follow the directions from above.
  • Testing blower circuit with a high-power bulb
    #3 16895727
    g107r
    Help: 811
    Rate: 993
    driwer78 wrote:
    Will it be the cube in the ignition?
    If I look correctly, it's possible, which is probably easy to check on the cube itself - pink / green wire? Or by doing what you've been doing so far
    driwer78 wrote:
    How do I put the tester on the fuse and the plus on the battery
    through the motor and resistors you should change the lighting by operating the switch. Are you "catching" this mass by the blower motor? Power the fuse with a high-power bulb, the small bulb limits the current to the engine.
  • #4 16895936
    driwer78
    Rate: 12
    Thanks for the help. I dismantled the cube in the ignition switch and there was a burned contact from this cable to the blower. I cleaned it, and now it works. I suspect that I will have to replace it with a new one.
  • #5 16896002
    pepe150
    Level 36  
    Help: 288
    Rate: 940
    According to the description, you wrote that the blower in the knob that controls the blower in the car does not work.
    Butter Butter.
    It is important that you found your problem.
  • #6 16928480
    driwer78
    Rate: 12
    Briefly, the cause of the failure was the cube in the ignition switch, and the burned contact from the wire that powers the air supply panel.
