Connecting a Conax Card Reader to MECOOL KIII Pro Amlogic S912 TV Box: Options?
kiu86 3561 4
  • #1 16705473
    kiu86
    Rate: 12
    I have a question about the MECOOL KIII Pro Amlogic S912 TV Box.
    I managed to buy TVBox for pennies as above. I currently use pre-paid television (NC +) and ITI 5800SX tuner (decoder owned) and here is the question whether there is a possibility to connect the card reader to the TV Box, probably it is a conax if I'm not mistaken? I would like to use this TV Box and opt out of the ITI5800SX tuner from NC + but this TV Box does not have a card reader (it has a DVB-T2 and DVB-S2 tuner). I wonder if there is any USB reader that would work with TV Box?
    Thank you in advance for your answer.
  • #2 16705598
  • #3 16705865
    kiu86
    Rate: 12
    The fact that this card is inseparable from the tuner, I know I have a different card, from the old SD and it works with all tuners, and I will give the current set to my parents-in-law or sell it, provided that the TV Box can be expanded with a card reader.
  • #4 17391861
    bratmat
    Theoretically, a USB reader should work if it's one that works on Android. There is oscam in the box so you can configure the reader.
  • #5 17764941
    TaiPan
    Rate: 12
    Can you refresh the topic? You have successfully installed a reader for this MECOOL K III Pro box. If so, which reader should be purchased for nc +?
