Nbox Enigma2 Configuration: Total Commander, Wi-Fi, FTP, Oscam, User/Password Setup & Remote Access
skiper56 10368 7
  • Clarifying FTP and Oscam login setup
    #1 16806364
    skiper56
    Rate: 49
    I have a configuration problem in enigma2. I am connected using total comander over the wi-fi network with the tuner as well as the computer.
    The question is whether to enter data into it (user, password, domain) I can do this by total comander via FTP or only through oscam-by it I tried according to the instructions posted in the forums but it does not work for me. And in addition whether everything can be done remotely from the position of a laptop or via the nbox's remote control
    Please help
  • #2 16807295
    KIEROWCA_VW
    Help: 273
    Rate: 676
    What exactly do you want to do?
  • #3 16810674
    skiper56
    Rate: 49
    Does the data enter correctly Nbox Enigma2 Configuration: Total Commander, Wi-Fi, FTP, Oscam, User/Password Setup & Remote Access Nbox Enigma2 Configuration: Total Commander, Wi-Fi, FTP, Oscam, User/Password Setup & Remote Access
  • #4 16810799
    KIEROWCA_VW
    Help: 273
    Rate: 676
    What are you getting at?
    What offer do you have?
    What do you want to get?
  • #5 16810969
    romeok01
    Help: 357
    Rate: 589
    It depends on which protocol you have the card, there is no Enable checkbox and in the Group, enter 1.
  • #6 16811285
    skiper56
    Rate: 49
    Nbox decoder - Nc + offer
  • #7 16811420
    romeok01
    Help: 357
    Rate: 589
    Again, you do not know if you are using a shared card in your home network, or if you want to configure the card inserted in the decoder.
    What kind of card is it?
    Conax - Blue or Cameleon - gray?
  • #8 16812671
    skiper56
    Rate: 49
    It's all about, the problem lay after the card with nc +, they exchanged for a new one.
The discussion revolves around configuring the Nbox Enigma2 system, specifically addressing issues related to user and password setup via Total Commander over a Wi-Fi connection. The user seeks clarification on whether data entry can be performed through FTP using Total Commander or if it must be done via Oscam. Responses highlight the importance of understanding the type of card being used (Conax or Cameleon) and whether it is a shared card or one inserted in the decoder. The user later clarifies that the problem was related to a card from NC+ that was exchanged for a new one.
