[Solved] Enigma2 NBOX BSK Equipment: OSCam Card Reading Failure, FEDC Absent - Troubleshooting
gorg81 23820 8
  • #1 17835536
    gorg81
    Rate: 17
    I have been reading, reading and reading since Friday and no solution works. Enigma2 NBOX BSK equipment. I had a multi-room split while there was a break. However, two years ago I changed to nboxy and newcs, (I have a small server at home for monitoring, ftp etc ...) everything connected with an alcatel LTE router from tmobil. Everything went until Friday, half of the channels went out on Friday, on Saturday most of the channels are now only CP. I have already tried on the Phoenix USB reader, in the decoder with the FEDC soft, but it turns out that the card did not catch the FEDC, I give the oscam screen from the readers reading.
    Now it is so that after inserting the card into the nbox with FEDC soft, even polsat does not light up, after connecting a USB reader and polsat lights up quickly in newCs.
    Do any of you know the remedy?
    I use hardware, I am no stranger to linux, I am familiar with the subject of the network, but in this case I am powerless.
  • #2 17835762
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Remove the EMM caching and unlock all EMMs on this card, then do an electric restart of the decoder. Set it to the TVP1 HD channel and leave it for a few hours.
  • #3 17835770
    gorg81
    Rate: 17
    Something more specifically in which file ?? oscam.config ??
    Please direct me.
  • #4 17835795
    netTv
    Level 32  
    Help: 193
    Rate: 579
    There should be no blockemm ... and emmcache entries in the oscam.server section [reader].
    Sometimes you have to reboot the decoder several times for the next rom versions to be updated. You must have rom 4E cards and you have 41.
  • #5 17837140
    gorg81
    Rate: 17
    Gentlemen, oscam r11425FEDC
    Such settings for sci0
    Will the powers pass? and Rom ??
  • #6 17837354
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Delete everything below group and restart the decoder with power supply.
  • #7 17837382
    gorg81
    Rate: 17
    If I understand correctly, delete everything from the entry via the browser. Then Save and restart after powering ??
    If I did it, I released the ICA and TVP1 HD permissions once again and wait ??
  • #8 17837757
    netTv
    Level 32  
    Help: 193
    Rate: 579
    To remove the entries in the oscam.server file are below the group = 1 line . But only for sections [READER] with label = sci0 .
    It is not necessary to renew the rights by the ICOK.
    Set for C + cameleon mhz = 400
    The rest as you understood.
  • EMM cache dump and ICA permissions restored card reading
    #9 17869091
    gorg81
    Rate: 17
    Just like colleagues wrote a tuner card, dump all EMM cash and unlock EMM in oscam configuration, decoder card and let go of ICA permissions. We are waiting, half of the channels worked for me after 30 minutes, I took out the card, restart the enigma, once again the ICA permissions and in the second half of the hour they all surprised. Has taken the latest ROM and powers and it comes. No FEDC so far.
    Can be closed.
The discussion revolves around troubleshooting OSCam card reading failures on Enigma2 NBOX BSK equipment, particularly after a multi-room split. Users report that channels have gone out, with specific issues related to the FEDC soft not recognizing the card. Suggested solutions include removing EMM caching, unlocking EMMs, and ensuring proper configuration in the oscam.server file. Users are advised to delete specific entries related to the reader configuration and to reboot the decoder multiple times to refresh card permissions. Some users have successfully restored channel access by following these steps, while others continue to seek solutions.
