Samsung LE40B650 TV: Internet Not Working, Updated Software, Service Not Supported Issue
guitarsman 4827 7
  • Internet service still unsupported after firmware update
    #1 16709040
    guitarsman
    Hello. I know that the topic has been drilled before. But I read all the posts and unfortunately didn't find the answer.
    So to the point. I applied all the advice and nothing. The link is ok. Software updated to T-CHL7DEUC_3001.1_Step2.exe.
    In Plug & Play settings, everything in accordance with www.youtube.com/watch?v=mmoIGNOlUN0. After pressing INTERNET @ on the remote control, the cursor spins for a moment and the message "Service not supported" is displayed.
    I am asking for help, for which I thank you in advance.
  • #2 16709166
    1 PAWEL
    Help: 674
    Rate: 1365
    You do not write from whom you have the internet and what settings you have for the PC.
  • #3 16709167
    KOCUREK1970
    Help: 3865
    Rate: 5498
    What, how, what, what, what, cable, wifi?
    Describe exactly what you have a problem with - because your post says nothing.
    And what does internet on TV have to do with a movie?
  • Samsung widgets no longer supported on this TV
    #4 16710085
    guitarsman
    Gentlemen, I wrote everything in the post. The problem was in starting the application. The topic is overwhelmed. Thank you for your interest. The applications were successfully launched, unfortunately Samsung no longer supports the use of "this era" widgets.
    What's the difference? I wrote that the link is ok.
    Well, unless someone is overwhelmed and can configure it, for example youtube?
  • #5 16710100
    1 PAWEL
    Help: 674
    Rate: 1365
    But no basic data. Best regards.
  • #6 16710809
    guitarsman
    What data is it about? Net from multimedia, ok configuration, tv catches ip by itself, gateways etc. Everything is ok with the connectivity test. The problem is the inability to log into eg youtube widget. Shows that the version is from 2010. Connecting to eg the "weather" widget takes place ok. After entering the city, the widget shows the current data.
  • #7 16711173
    japycz321
    Help: 92
    Rate: 141
    Youtube gave up Flash technology some time ago, which caused many models of older TVs and other devices to stop supporting it. I wouldn't expect this functionality to be added (restored) to old models.
  • #8 16711946
    guitarsman
    I read so. Thanks for the help.
The discussion revolves around a Samsung LE40B650 TV experiencing internet connectivity issues, specifically displaying a "Service not supported" message when attempting to access internet applications. The user confirmed that the TV's software was updated to T-CHL7DEUC_3001.1_Step2.exe and that the network settings were correctly configured. Despite these efforts, the user faced difficulties launching applications like YouTube, which is attributed to the discontinuation of Flash support by YouTube, affecting older TV models. Other widgets, such as the weather application, functioned correctly, indicating that the connectivity itself was not the issue.
