Connecting Internet on Samsung LE46B650 TV: LAN Cable, Manual Network Settings & Solutions
stasiu43 7305 11
Why does my Samsung LE46B650 show "function unavailable" when I press the Internet button even though the LAN connection and manual network test are OK?
The Internet feature on Samsung B-series TVs was disabled by Samsung, so the LE46B650 can show "function unavailable" even when the network test passes. [#16187565][#16184454] You can try a firmware update via USB, but one user reported that the latest software still did not restore the widgets on a B652/B650 model. [#16184440][#17083504] The removed services included YouTube and other Internet widgets, so there may be nothing left to activate on this TV model. [#16184454]
  • Samsung LE46B650 internet function unavailable despite network test
    #1 16183929
    stasiu43
    Hello everyone, I've had Samsung LE46B650 for about 9 years and I would like to connect the internet to it, but it doesn't work.
    I connected the LAN cable to the TV, set the network manually, I did the network test and everything seems ok, but when I press the internet function on the remote control, it appears on the screen after a few seconds: the function is unavailable.
    If anyone knows this, please help.
  • #2 16184440
    Piotr2608
    Help: 851
    Rate: 4487
    Try to update the firmware. Latest version of the software - upgrade via USB.
    • T-CHL7DEUC_3001.1_Step2.exe (79.77 MB) You must be logged in to download this attachment.
    ZimTech Piotr Zimny
  • #3 16184454
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    At one time I also launched the Internet in Samsung LE37B650 but it turned out that I couldn't work with it a lot, information, weather etc. Samsung turned off Youtub-e and the rest did not interest me.
  • #4 16187061
    stasiu43
    Hello, could you describe in more detail how to do it, I'm rather green with this topic ...
  • #5 16187565
    wlodarek1
    Rate: 68
    Samsung has turned off all Internet widgets for the B series of its TV
  • #6 16187799
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @ stasiu43
    As for the software update - this is an exe file, copying it to USB will do nothing, run it, provide a USB card / pen and install a software there and connect it to the TV.
  • #7 16200567
    stasiu43
    KOCUREK1970 wrote:
    @ stasiu43
    Could you describe in more detail how to do this I am rather green with this topic.
  • #8 16201901
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Click 2x. Exe file on this soft computer,
    indicate the memory and wait for the end of the software installation on the pen,
    disconnect the pen from the computer,
    connect it to the tv with the tv turned off
    turn on the tv power,
    turn on tv.
    In addition, the software on the www describes the procedure for installing this software in a pdf file.
  • #9 17082811
    DzJAREK
    Was this upgrade successful?
  • #10 17083504
    wlodarek1
    Rate: 68
    I've uploaded the latest soft to my B652T4w and it doesn't work. They took us widgets and that's it tyle
  • #11 17085463
    DzJAREK
    Will netflix work on the latest software in LE46B650T2WXXH?
  • #12 17085565
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @DzJAREK
    Install and see.
The discussion revolves around connecting the Samsung LE46B650 TV to the internet via a LAN cable. The user reports that despite manual network settings and successful network tests, the internet function remains unavailable. Responses suggest updating the TV's firmware, as Samsung has disabled internet widgets for the B series TVs, including the LE46B650. Detailed instructions for firmware installation via USB are provided, emphasizing the need to run the software on a computer before transferring it to the TV. Users express frustration over the lack of functionality for internet services like YouTube and Netflix after updates.
