50-55 Inch TV Recommendations for 3000-3500 Budget: 4K UHD, HDR, Wi-Fi, USB & HDMI Features
piterski.76 4143 9
How can I choose a 50–55 inch TV under 3,000–3,500 PLN with 4K, HDR, Wi‑Fi, USB/HDMI, and a 100 Hz VA panel for mostly night viewing?
At 3,000–3,500 PLN, you won’t get a 50–55 inch TV that combines a VA panel, 100 Hz refresh rate, and the rest of your requirements; in this budget you should expect a lower-midrange 55-inch set with a 50 Hz matrix, or raise the budget to about 5,000–5,500 PLN for 100 Hz [#16621682] For evening viewing and a straight-on seat, VA is the better choice, and IPS should be avoided because blacks go gray at night [#16622697] Suggested models in your budget were Panasonic 50EX700 or Samsung KU64xx, with the note to verify that the Samsung version actually has a VA panel; TCL C70 was mentioned as another option if you can wait, but it is 50 Hz and lacks motion smoothing [#16621682] When the budget was raised to 4,000 PLN, the answer was still that it is not enough for a noteworthy 50-inch VA + 100 Hz TV [#16623131] If you can accept FHD instead of 4K, the recommended 100 Hz models were LG EG910V, Samsung 60J6240, and Sony W805C/W809/W755 [#16623779]
  • #1 16621526
    piterski.76
    As in the subject: I am looking for a 50-55 inch tv at a price preferably up to 3000 (although I can add up to 500 to this amount) that would meet the following requirements - what do you recommend? Thanks in advance for any info:
    1. How big is the room where the TV should be? Ok. 2,8x3,2
    2. How far are we from the TV screen? 1-2m
    3. How many people sit in front of the TV? 1
    4. Are we sitting in front of the screen or sideways to the screen? directly.
    5. Is the TV supposed to stand or hang? Both versions are considered
    6. How does the sun shine in the room? The TV will stand sideways to the window. The sun is falling from the right, the room is sunny.
    7. What is your TV currently? I do not have
    8. What do we want the TV to have? 4K UHD, HDR, Internet, Wi-Fi, DLNA, USB - multimedia, USB - recording, HDMI, USB x3
    9. What signal will be connected to the TV? DVB-T (MPEG-4), DVB-T2, DVB-S2, DVB-C, analog,
    10. What devices? Laptop via WiFi
    11. How many hours a day should the TV work? I can't tell
    12. Does it happen that you watch only one program for several hours? No
    13. What kind of programs do you watch most often? Movies, series, sport, entertainment
    14. Are you going to surf the internet? Yes
    15. Are you going to play games - no
    16. Brand preferences? Lack
    17. Size preferences? 50 -55 "
    18. What annoys you on TVs? Long channel switching
    19. Do you watch more in the evenings or during the day? Most at night.
    20. Up to what maximum amount do you plan to buy? PLN 3500, however, I am able to slightly exceed this amount.
    21. How often do you change TV sets at home? No
    22. Do you use internet applications often? It happens.
    I would prefer that tv was not on Android, because from what I learned, this is not the best platform - if it is different then please get me out of error. And finally - matrix with refreshment min. 100 Hz.
    Piotr
  • #2 16621682
    Ludwik XVI
    Help: 1325
    Rate: 788
    piterski.76 wrote:
    : I am looking for a TV 50-55 inches for the price preferably up to 3000 (although I can add up to 500 to this amount)
    Unfortunately, there is no TV that would meet these three conditions at the same time.
    You need a TV with a VA matrix (night viewing).
    For 3-3.5 thousand PLN you will buy a lower middle class TV in size 55 inches and a 50 Hz matrix.
    E.g. Panasonic 50EX700 or Samsung KU64xx (here you must always check if there is a VA matrix, samsung non stop)
    If you are not afraid of Chinese people, then you can wait a moment and see TCL c70 - it will be in stores in September. 50hz, VA, no picture liquefier.
    If you want 100Hz then you need to raise the budget to about 5-5.5 thousand PLN.
  • #3 16622214
    piterski.76
    Thanks for the answer. How about this model: Philips 49PUS6561? This is not VA, but I found a lot of good reviews about it and ... it is in the budget
  • #4 16622683
    Ludwik XVI
    Help: 1325
    Rate: 788
    piterski.76 wrote:
    Philips 49PUS6561
    I had this TV and sold it over a month ago.
    Look for my opinions because I wrote about him many times.
    In general - he didn't do it for me. Unsuccessful model.
  • #5 16622697
    Fallen89
    Rate: 12
    Parents have this Philips 6561. In the day it may still be somehow suitable for watching, although it is impossible to get a good reproduction of movement.
    PNM jerks too much even on the Minimum so the liquefier is completely turned off and the Clear LCD has the impression that it is slightly 'handicapped', i.e. it reduces blur in motion but it has nothing to do with Blur 10 in Samsung.
    As for the evening viewing, it was recently inspired by the Chmielewski test (LG SJ810 and Panasonic EX780), evening photos of both TVs:
    http://www.tvtest.pl/wp-content/uploads/Panasonic-58EX780-kontra-LG-55SJ810-08.jpg
    I also took a night photo of my Samsung on VA and their Philips. KSa 7000 calibrated professionally (calibrated), but for the test I went into 'Standard' and set the settings as they were by default in the movie mode. Philips also on the default 'Film':
    Philips
    http://i.imgur.com/3Et2kJL.jpg
    Samsung:
    http://i.imgur.com/g6Hfrhk.jpg
    Besides, what about the fact that IPS has good color reproduction at an angle, if during evening viewing the black turns completely gray and it looks TRAGIC:
    http://i.imgur.com/9tm6SKY.jpg
    You wrote yourself that you watch straight and mainly at night because don't take IPS under any circumstances, you will quickly regret your choice.
    Anyway, I'm just a gray user, so LOCOLOCO will bring me down to the ground that I am talking about stupidity so that it is not just my opinion, IPS vs VA falls similarly:
    IPS:
    http://i.rtings.com/images/reviews/x850d/x850d-uniformity-large.jpg
    VA:
    http://i.rtings.com/images/reviews/ks8000/ks8000-uniformity-large.jpg
    and even worse in the lower price shelves:
    http://i.rtings.com/images/reviews/uf7700/uf7700-uniformity-large.jpg
    In the same price shelf (UEKS7000 vs Sony XD85)
  • #6 16623103
    piterski.76
    Indeed, this matrix looks quite weak. And if I raised the budget to 4000, would it be able to find something about 50 inch noteworthy with a VA matrix and 100Hz refresh rate? Is this still not enough?
  • #7 16623131
    Ludwik XVI
    Help: 1325
    Rate: 788
    piterski.76 wrote:
    budget up to 4000 would be able to find something about 50 inch noteworthy with a VA matrix and 100Hz refresh rate? Is this still not enough?
    Unfortunately, still not enough ... although FHD, 100 Hz, VA you would find so much that it is practically the same exhibition :(
  • #8 16623654
    piterski.76
    So what would you recommend with FHD?
  • #9 16623779
    Ludwik XVI
    Help: 1325
    Rate: 788
    FHD i 100Hz
    LG eg910v
    Samsung 60j6240
    Sony W805c lub 809 lub 755
  • #10 16623897
    piterski.76
    Thanks for the hint. If anyone else would like to share their tips I will be grateful.
    P
The discussion revolves around recommendations for a 50-55 inch TV within a budget of 3000-3500 PLN, focusing on features such as 4K UHD, HDR, Wi-Fi, USB, and HDMI. Users express concerns about finding a model with a VA matrix suitable for night viewing and a 100Hz refresh rate. Initial suggestions include the Panasonic 50EX700 and Samsung KU64xx, with a caution to verify the matrix type. The Philips 49PUS6561 is mentioned but criticized for its performance, particularly in motion reproduction. Users inquire about alternatives with a higher budget, but it is noted that even at 4000 PLN, options remain limited. Recommendations for FHD models include LG EG910V, Samsung 60J6240, and Sony W805C/809/755.
