[Solved] Best 55-Inch TV for 3500 PLN: Samsung EU55NU7402 vs Philips 55PUS6561 or Other Options?
Norbi-82 2565 7
  • #1 17463463
    Norbi-82
    Hello, I have a question: what would you recommend a 55-inch TV set to about 3500 PLN. I found two samsung eu55nu7402 or philips 55pus6561. Which one would you recommend more, or maybe something else.
  • #3 17464256
    Norbi-82
    1. How far are you sitting from the TV screen? 3m
    2. Are you sitting in front of the screen or your side to the screen? Sideways, diagonally
    3. What TV do you currently have? Samsung 32 inch
    4. What brand do you prefer? Lack
    5. What size TV are you looking for? 55 inches
    6. What signal and devices will be connected to the TV? Cable TV
    7. What kind of programs do you watch the most? Movies
    8. Will you be playing games, and if so, on the console or on the PC? No
    9. Will you be actively using the TV's SMART system? Yes
    10. Do you watch in the evenings or during the day? Day and night, the advantage probably during the day
    11. How much money can you spend on buying a TV? PLN 3500
    Ludwik XVI
    Help: 1325
    Rate: 788
    You are sitting sideways, so rather an IPS panel.
    Samsung eu55nu7402 is ok but this is a VA panel - When viewed sideways, it will lose colors a lot.
    See this year's Panasonic TX-55FX700E - 60Hz matrix, IPS, good liquifiers for 60Hz.
    With LG you have a very good 120 Hz 55SK8100 - or SK8000 (also on IPS) - it's already a TV with SUHD.
    lesmian45
    Level 19  
    Help: 19
    Rate: 17
    Philips 8303 - IPS matrix with good contrast for this technology. :)
    Mariano11
    Help: 57
    Rate: 43
    In fact, the 8303 will fit in the price range.
  • #7 17473761
  • #8 17592591
    Norbi-82
    I bought a Philips 8303. Thank you for the hints. Really great picture. I recommend
The discussion revolves around selecting a 55-inch TV within a budget of 3500 PLN, specifically comparing the Samsung EU55NU7402 and the Philips 55PUS6561. The user provided details about their viewing distance (3m), angle (sideways), and preferences for SMART functionality and daytime viewing. Responses highlighted the importance of panel type, recommending IPS panels for better color retention at side angles. Alternatives suggested include the Panasonic TX-55FX700E and LG 55SK8100, both featuring IPS technology. The Philips 55PUS8303 was also recommended for its 100Hz native matrix and low input lag, which the user ultimately purchased and praised for its picture quality.
