Entrance Door Installation: Left or Right? Opinions Needed on Correct Door Orientation
Duch__ 14109 16
How can I tell whether an exterior door is left-hand or right-hand from photos of its outside and inside views?
These are right-hand doors. The clearest rule given is to stand on the hinge side: if the hinges are visible on the right, it is a right door; if the hinges are visible on the left, it is a left door [#16716645] Multiple replies also state that the pictured door opens to the right, including that it opens inward to the right [#16716634] [#16716638] [#16716906] [#16717071] [#16717086]
  • Need interior and exterior views to determine handing
    #1 16716620
    Duch__
    Help: 33
    Rate: 1598
    I know this is not a construction forum, but there may be an expert on the subject.
    I did not take care of the seller during the installation of the door in the newly built house and claims that he installed the door correctly as ordered. I will not indicate whether I ordered the left or right door, but I would like to know your opinion on what they are. These are external doors.
    Exterior view:
    Interior view:
  • #2 16716634
    any56
    Help: 656
    Rate: 840
    The pictures show the right door ...
  • #4 16716638
    marek49ae
    Help: 57
    Rate: 254
    This is the right door Entrance Door Installation: Left or Right? Opinions Needed on Correct Door Orientation
  • #5 16716639
    kokapetyl
    Help: 1787
    Rate: 2108
    For me, these are left.
  • Door handedness determined by visible hinges
    #6 16716645
    Robert B
    Help: 2027
    Rate: 1412
    @kokapetyl You are left alone :lol:
    Train yourself and don't write nonsense!
    http://www.stolbud.pl/faq/drzwi-wewnetrzne/14...672-jakie-odroznic-drzwi-prawe-od-lewych.html
    Stand in front of the door from the side of visible hinges . If we see the hinges on the right - they are the right door, if we see the hinges on the left - they are the left door.
  • #7 16716657
    kokapetyl
    Help: 1787
    Rate: 2108
    Robert B wrote:
    @kokapetyl You are left yourself :lol:
    We learn all our lives. But thanks to you I am "righteous" :D
  • #8 16716882
    Duch__
    Help: 33
    Rate: 1598
    By. door sellers are left :crazyeyes: :|
  • #9 16716906
    kkknc
    Help: 1916
    Rate: 6721
    This is the right door.
  • #10 16716930
    Robert B
    Help: 2027
    Rate: 1412
    :lol: :lol: :lol:
  • #11 16716956
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Well, according to the seller, maybe they are "left", but they open up as right.
  • #12 16717043
    telecaster1951
    Help: 829
    Rate: 818
    Like a bull right. The door to you opens to the right. If you ordered the left one, and the one sold the right one, then let it pay the contractor for replacing the door frame. Hen, like in a cabaret ...
    Don't you have a cracked lintel there?
  • #13 16717051
    szkieletor11111
    Help: 63
    Rate: 149
    The door, like a bull, opens right inside. I am surprised that it is so difficult to understand.
  • #14 16717056
    Duch__
    Help: 33
    Rate: 1598
    [Quote = "telecaster1951"]
    The lintel is not cracked. It is a piece of steel wire from the remnants after the formwork has been attached.
    During the conversation the guest tried to push me to the left and right for outside doors. I ordered the left one ...
  • #15 16717062
    telecaster1951
    Help: 829
    Rate: 818
    Duch__ wrote:
    that left-right views are different for outside doors.
    I wonder where ... It's talking nonsense. The door is right, as it opens to the right - to yourself.
    And what does it matter? And right and left can open inwards.
  • #16 16717071
    szkieletor11111
    Help: 63
    Rate: 149
    A colleague asked a question in the post - so we answer. Right door.
  • #17 16717086
    deejay205
    Of course it's right
The discussion revolves around the correct orientation of an external door installed in a newly built house. The original poster is uncertain whether the door was installed as left or right-handed, leading to various opinions from forum members. Some assert that the door opens to the right, while others argue it is a left door based on the seller's claim. The conversation includes references to external resources for distinguishing between left and right doors, with some participants humorously debating the definitions. Ultimately, there is confusion regarding the door's orientation, with suggestions that if the door was incorrectly installed, the seller should be responsible for rectifying the issue.
TL;DR: Use 1 simple rule: “Stand on the hinge side—hinges on the right = right-hand, hinges on the left = left-hand.” [Elektroda, Robert B, post #16716645]
Why it matters: This prevents costly reorders and disputes about exterior door orientation for builders and homeowners.
How do I tell if my door is left-hand or right-hand quickly?
Use the hinge-side test. Stand on the side where you can see the hinges. If hinges sit on your right, it’s a right-hand door. If they sit on your left, it’s a left-hand door. “Stand in front of the door from the side of visible hinges” is the expert cue. [Elektroda, Robert B, post #16716645]
Does inward vs. outward swing change left/right handing?
No. Handing depends on hinge location only. A door can open inward or outward and still be left or right based on where the hinges are when viewed from the hinge side. “Right and left can open inwards,” as one expert notes. [Elektroda, telecaster1951, post #16717062]
Are exterior doors labeled differently from interior doors?
No. The same hinge-side rule applies to exterior and interior doors. Claims that exterior doors use a different left/right convention are incorrect. Use the same visual hinge check to avoid confusion when ordering or inspecting. [Elektroda, telecaster1951, post #16717062]
In the thread photos, is the entrance door left or right?
Right-hand. Multiple contributors identified the pictured entrance door as right-hand based on visible hinge placement and opening direction to the right when viewed from the hinge side. [Elektroda, any56, post #16716634]
What should I say if a seller insists my right-hand door is actually left-hand?
Ask them to apply the hinge-side test on-site. Stand on the hinge-visible side together and identify hinge position. Document with a photo. If the supplied hand differs from the order, request corrective action in writing. [Elektroda, telecaster1951, post #16717062]
What happens if a wrong-hand door was installed?
Correction may require replacing the frame and leaf to match the ordered hand. One pro notes the seller should cover contractor costs if the wrong hand was provided. Confirm terms in your purchase agreement before work starts. [Elektroda, telecaster1951, post #16717043]
Can I rely on opening direction like “opens right” to decide handing?
Only when you’re on the hinge-visible side. “Opens to you on the right” means right-hand if you stand on the hinge side. Without that context, the phrase can mislead. Always pair opening direction with the hinge-side reference. [Elektroda, telecaster1951, post #16717043]
What is “door handing” in simple terms?
Door handing is the classification of a single-swing door as left-hand or right-hand, determined solely by hinge location when viewed from the hinge side. One simple rule decides it every time. [Elektroda, Robert B, post #16716645]
3-step how-to: verify handing on-site before installation?
  1. Stand on the side where hinges are visible.
  2. Note hinge position: right = right-hand; left = left-hand.
  3. Match your finding to the order/spec sheet before drilling or fixing the frame. [Elektroda, Robert B, post #16716645]
Does the lock or handle placement affect left/right classification?
No. Lock and handle positions do not define handing. The sole determinant is hinge location when you face the hinge-visible side. Verify hinges first to avoid ordering errors. [Elektroda, Robert B, post #16716645]
What if photos make it hard to see the hinge side?
Ask for a straight-on photo from the hinge-visible side or a short video showing the hinge line. In the thread, clear hinge visibility led to a right-hand identification. [Elektroda, marek49ae, post #16716638]
Is there consensus in the thread on the example door?
Yes. Contributors repeatedly confirmed it is a right-hand door using the hinge-side rule and opening direction to the right. “Of course it’s right,” one member concluded. [Elektroda, deejay205, post #16717086]
Edge case: could a seller argue different rules for outward-opening entrances?
Some try, but it’s incorrect. Exterior status or outward swing does not change handing. Apply the hinge-side test to settle the question consistently. “It’s talking nonsense,” as a pro put it. [Elektroda, telecaster1951, post #16717062]
Why do buyers and sellers still disagree about handing?
They use different reference viewpoints. The fix is to standardize on the hinge-visible side when deciding left/right. This removes ambiguity and prevents costly callbacks. [Elektroda, Robert B, post #16716645]
