[Solved] VW Lupo 1.4 16V: Recurring Check and EPC Dashboard Lights During Hot Engine Start
patrycja17011996 5865 2
  • #1 16717857
    patrycja17011996
    Hello, I need help. Problem. Both the "check" and "epc" lights turn on on the board, then the car goes out and always turns on when the engine is hot and when the car starts again they disappear and the problem arises again. What to do? What is the reason for this?
    Moderated By T5:
    3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and a brief description of the fault.
    Trawik
    Help: 75
    Rate: 442
    Connect under the computer will prompt.
  • #3 18745814
    patrycja17011996
    Connecting the computer and removing errors
