[Solved] Golf 1.6 16V MK4 - EPC & Engine Light On, Errors 17550 & 17961 - Suggestions & Solutions?
kano1975 17268 3
  • #1 16778482
    kano1975
    Help: 15
    Rate: 38
    Someone will suggest something in the subject? EPC and Engine will light when the engine is running.
    Errors in the attached screenshot.
  • #2 16778519
    mario 77
    Help: 66
    Rate: 335
    Turn on the ignition and check the value of the MAP sensor.
  • #3 16778583
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    Check the operation of the EGR system, a common problem with such errors
  • #4 17767287
    kano1975
    Help: 15
    Rate: 38
    It was an EGR system, thanks for your help, solved!
    Charles
