Keyboard Issue: Left Ctrl Mutes Sound on Natec Keyboard in Windows 7 - How to Fix?
9423 11
How can I stop the left Ctrl key on a Natec Starfish 2 keyboard from muting the sound in Windows 7?
This is most likely a keyboard remapping or keyboard fault, not a normal Windows 7 setting, so first check the keyboard’s own software for custom key assignments and test whether the key is being interpreted as something else [#16719055] A small key-test program showed the mute key as `Volume_Mute`, while pressing the left Ctrl produced `LCtrl Volume_Mute`, which points to an odd keyboard input problem rather than a standard OS shortcut [#16719352] If possible, test the keyboard in Linux LiveCD or on another computer; if another keyboard works normally, the Natec keyboard is damaged [#16718666][#16719390] If you cannot test elsewhere, checking the keyboard in another environment is still the recommended way to separate a hardware fault from a system shortcut [#16719055][#16719211]
  • #1 16718644
  • #2 16718666
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Connect another functional keyboard and check if it is ok, if it means that it is damaged.
  • #3 16718694
  • #4 16718769
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Then check how you will have it, there is no other option.
  • #5 16719055
    sylweksylwina
    Help: 1882
    Rate: 2355
    ruensky123 wrote:
    are there any specific pc keyboard settings, key settings?
    You haven't even written what specific keyboard model it is. Some manufacturers of input devices, e.g. the keyboard, provide software for changing the operation of the keys - you probably know something about it, as you have mute on the numeric keypad. So you can check the settings in this software. Another option is if someone wrote the keyboard damage. Still another option is to interpret the keys in the operating system - check by connecting the keyboard to another computer or via live linux.
  • #6 16719070
  • #7 16719211
    310artur
    Help: 980
    Rate: 670
    Run LiveCD with Linux unless you can. I have the impression that someone has to come to you and do it for you because you can't, you can't, you don't want ... I understand that this is a PC from the prison library and you are embedded and hence the limited possibilities ...
    Maybe try, in the attachment I will give you the program. Unpack and run it. This program shows what key you press. Press the one above the numeric one from mute and look what will appear. Then press problematic ctrl and see if it's the same or different.
    • ShowOff.zip (246.29 KB) You must be logged in to download this attachment.
  • #8 16719352
  • #9 16719390
    310artur
    Help: 980
    Rate: 670
    Well, it's starting to look weird like a keyboard error.
    Check on this Linux it doesn't require any installation.
    Download the system image here:
    https://linuxiarze.pl/download_antix/
    antiX 16.2 x64 base 514MB
  • #10 16719436
  • #11 16719439
    folkswagen
    Help: 7
    Rate: 12
    Please do not get used to it!
    Just patiently search the so-called keyboard shortcuts and the case. Sometimes the graphics card software provides "default" shortcuts for combinations with specific keys. For example - ctrl + a + v = video playback. Recently it was - watching amateur video. I know people turn off very quickly. I try to be SUBSTANTIVE ...
  • #12 16719451
A user reported an issue with their Natec keyboard, specifically that the left Ctrl key mutes the sound on their Windows 7 system. Despite disconnecting and reconnecting the keyboard and rebooting the computer, the problem persisted. Suggestions included testing with another keyboard, checking for specific keyboard settings or software provided by the manufacturer, and using a LiveCD with Linux to diagnose the issue. The user identified their keyboard model as Natec Keyboard STARFISH 2 Slim Black USB but was unable to connect it to another computer for testing. Eventually, the user noted that the issue resolved itself, possibly related to their frequent use of the Ctrl key for copy-paste functions.
TL;DR: One simple test can isolate this: “Connect another functional keyboard and check.” If the issue vanishes, the first keyboard is at fault. [Elektroda, Kolobos, post #16718666]
Why it matters: This FAQ helps Windows users fix keyboards that mute audio when pressing Left Ctrl, saving time and avoiding unnecessary replacements.
Why does pressing Left Ctrl mute my sound in Windows 7?
Your keyboard is sending a mute command alongside Left Ctrl. A key test showed “LCtrl Volume_Mute” on press. That indicates a mis-mapped key signal from the device, not Windows hotkeys alone. This can result from firmware mapping, stuck function layers, or hardware faults in the keyboard matrix. Confirm with a key display tool, then try another keyboard. If the behavior disappears, replace or reflash the original device. [Elektroda, 2649457, post #16719352]
How can I quickly tell if it’s the keyboard or Windows?
Do a swap test. Connect a different known-good keyboard. If the mute-on-Ctrl issue goes away, the original keyboard is faulty. If it persists, investigate software or OS-level hotkeys. This isolates hardware from system causes fast and reliably. “Connect another functional keyboard and check.” [Elektroda, Kolobos, post #16718666]
What tool can show what my key really sends?
Use a simple key display utility. Run it, press the dedicated mute key to see its label, then press Left Ctrl and compare outputs. In the reported case, the tool showed “Volume_Mute” for the mute key and “LCtrl Volume_Mute” for Left Ctrl, confirming a double signal. [Elektroda, 2649457, post #16719352]
Is vendor software remapping my keys?
Some keyboard makers provide software that changes how keys behave. If installed, check it for custom shortcuts or function layers tied to Ctrl. Disable, reset profiles, or uninstall to test. As one expert noted, “manufacturers provide software for changing the operation of the keys.” [Elektroda, sylweksylwina, post #16719055]
How do I test outside Windows without installing anything?
Boot a LiveCD/LiveUSB Linux session. It runs from media and requires no installation. If Left Ctrl still mutes audio there, it points to hardware. One helper recommended downloading an antiX Linux image for this purpose. This isolates OS factors cleanly and safely. [Elektroda, 310artur, post #16719390]
What if I don’t have a spare PC or USB drive?
You can delay OS isolation and use the key display tool first. If it shows “LCtrl Volume_Mute,” treat it as a device-side issue and plan a replacement. Avoid relying on copy‑paste shortcuts until resolved to prevent accidental mutes. This is a practical edge case. [Elektroda, 2649457, post #16719352]
Could the issue be a physical keyboard fault?
Yes. Experts flagged possible keyboard damage or matrix issues when keys emit unexpected functions. If another keyboard works normally, the original unit likely has a hardware defect. In that case, repair is uneconomical; replacement is the fix. [Elektroda, sylweksylwina, post #16719055]
Did this exact problem ever resolve on its own?
Yes. The reporter said it “fixed itself” after frequent Ctrl use. That suggests a transient contact or state-latch cleared over time. Still, monitor for recurrence, because intermittent faults often return under load or humidity. [Elektroda, 2649457, post #16719451]
What’s a LiveCD?
A LiveCD is a bootable operating system you run from external media without installing to disk. It’s ideal for hardware diagnostics. In the thread, antiX 16.2 x64 base was suggested, with a 514 MB image size, indicating a lightweight option. [Elektroda, 310artur, post #16719390]
How do I run the key test step by step?
  1. Launch the provided key display program.
  2. Press the keyboard’s dedicated mute key and note the label.
  3. Press Left Ctrl and check if the label matches or includes mute. If it shows mute with Ctrl, the keyboard is mis-signaling. [Elektroda, 310artur, post #16719211]
Can graphics or media software assign global mute to Ctrl?
Hotkey suites can bind media actions, but the captured output “LCtrl Volume_Mute” indicates the device itself sends mute with Ctrl. Disable any hotkey tools to be sure, but prioritize hardware isolation with a second keyboard test. [Elektroda, 2649457, post #16719352]
Does the exact keyboard model matter for troubleshooting?
Yes. Knowing the model helps find vendor utilities or firmware quirks. The affected unit was a NATEC Keyboard STARFISH 2 Slim Black USB. Search vendor support for remap tools or updates specific to this model. [Elektroda, 2649457, post #16719070]
I rely on Ctrl+C/Ctrl+V. How can I avoid accidental mute?
Until fixed, rebind copy/paste to Right Ctrl with a remap tool, or use Shift+Insert for paste. Alternatively, use on‑screen keyboard for critical tasks. Replace the keyboard if hardware is confirmed faulty to restore normal shortcuts. [Elektroda, sylweksylwina, post #16719055]
What’s the fastest single check to start with?
Swap in a working keyboard. If Left Ctrl stops muting audio, you’ve confirmed a device issue in seconds. It’s the most time‑efficient isolation method and avoids OS changes. “Connect another functional keyboard and check.” [Elektroda, Kolobos, post #16718666]
