VW Crafter 2.5 tdi 2009 163ps: Starting Issues with No Computer Errors, Rail Pressure Query
aras_nt 7131 2
  • #1 16720907
    aras_nt
    I have a problem with my father's car.
    Vw Crafter 2.5 tdi 2009 163ps
    The car fires on a cake or a cold engine - but not always
    The computer gives no error! There wasn't even anything to delete.
    I am worried about the pressure on the rail, because when turning the starter is 60/70 bar,
    I don't know what value it should have?
    Car in the family of 6 years and never a problem!
    This is the first time ...
  • #2 16720941
    sadek1979
    Cars specialist
    Help: 231
    Rate: 1408
    First, what is the speed of the starter (shaft), then does the pressure increase as you turn ???? Sometimes it is so that the starter is spinning like crazy and the engine does not see the rotation - damaged shaft sensor - no errors. Start by checking the parameters and vcds, not the universal one because sometimes they distort.
  • #3 16720961
    aras_nt
    The engine speed shows fine. I will check exactly how much it spins on the starter. But it looked okey ... i.e. after firing on the cake, the required and actual pressure was equal.
    Added after 13 [hours] 54 [minutes]:
    I checked the engine speed while turning the starter and gives from 210 to 260 revolutions. I unplugged the valves on the rail and the pump but it did not help. Through the computer, I activated the pump in the tank and you can hear that it is walking, but I do not know what pressure it gives. Today, under the firing rectifier during shooting, the pressure on the bar was up to 80 bar ... from what I read in this CR system, it should be about 180 bar for the car to start. After firing on the cake, the pressure on the rail during idling is 300 bar which keeps well ... but during firing I noticed that the pressure on the rail increases slowly, from 220 to 300 bar takes 3/4 seconds ... should ?
    Added after 8 [hours] 44 [minutes]:
    thank you for your interest! on this forum hardly helps ... ps problem solved by yourself!
