18650 Battery Dimensions for eVic-VTC Mini E-Cigarette: Comparing Short & Long Models
kriss1974 6804 7
  • 18650B cells are about 3 mm longer
    #1 16724051
    kriss1974
    Rate: 79
    WELCOME to "elektroda.pl" forum members
    I have a problem with the dimensions of the 18650 battery because some are shorter and the other is longer by almost 3mm, which prevents me from mounting them in my eVic-VTC mini e-cigarette.
    The longer batteries are marked with B after the 18650 inscription or the letter B means that the batteries are longer.
    I mean, I want to buy batteries for my eVic-VTC mini and I don't want them too long again.
    Many thanks in advance for any help.
    Spoiler:
    Spoiler:
  • #2 16724107
    Pedros050
    Help: 2471
    Rate: 3923
    Hello. The easiest way is to remove the batteries from your E-cigarette and measure the length and the case is solved.
  • #4 16724161
    kriss1974
    Rate: 79
    Thanks to "wojtek 9007" for a very specific and completely sufficient answer for me.
  • #5 16727305
    kriss1974
    Rate: 79
    I have one more question related to the battery, namely the PCB protection on the battery.
    Well, my e-cigarette eVic-VTC mini does not want to work with such a battery with protection because the screen flashes constantly and once shows the display that the battery is charged and a second later shows that the battery is low, but I cut off the protection in the battery, then everything works as it should.
    Is it a good idea to remove this protection, so far I have extended the connection of this protection with a cable so that I can use this battery in an e-cigarette without protection and for charging with protection, my charger is Lii-500.
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 847
    Hello - the heater in the e-cigarette consumes a lot of electricity (but only briefly), that's why
    the battery with electronic protection turns off the heater circuit.
    http://www.bto.pl/produkt/40948/pcml01s3107t-dla-36v-25a-fi14mm
    Battery recommended;
    https://e-dym.pl/pl/akumulatory/1945-akumulator-sony-vtc5.html
    Everything is described on the display;
    https://www.youtube.com/watch?v=IQqRkn3j1NI
    Important I used to smoke, now I have not been smoking for seven years.
  • #7 16728252
    kriss1974
    Rate: 79
    Thanks to "wojtek 9007" for really detailed and help.
    I'm also going to quit this addiction, so at the beginning I work in all directions but at the end of the road there is only strong will left, so respect you that you quit. :D
  • #8 16730388
    kriss1974
    Rate: 79
    The question was not how long the battery for my e-cigarette should be, because the shorter one fits only how to choose it when buying it so as not to buy a too long battery again, but I already got the right answer.
    I thought that the longer and shorter batteries were justified in their technical description.
The discussion revolves around the compatibility of 18650 batteries with the eVic-VTC Mini e-cigarette, specifically addressing the issue of varying battery lengths. Users highlight that some 18650 batteries are longer, marked with a 'B', which can hinder proper installation. Recommendations include measuring the existing battery length for accurate replacement and opting for high-discharge rechargeable batteries without PCB protection, as the eVic-VTC Mini may not function correctly with protected batteries. Users share links to specific battery models and express gratitude for the assistance received in resolving their queries.
