Elektrolux Ergorapido ZB13ER - Replacing the battery inr18650-15l for 25r
vesperos 11217 4
  • #1 16217340
    vesperos
    vacuum cleaner as per topic, after about a year of use the batteries fell.
    Mounted Samsung INR18650-15l interestingly with the description SDIEM and not SDI.
    My question, can you replace larger cells, e.g. INR18650-25R?
    Attached photo of the current battery.
    • Elektrolux Ergorapido ZB13ER - Replacing the battery inr18650-15l for 25r 2017-01-18 18.19.43.jpg (773.38 KB) You must be logged in to download this attachment.
  • #2 16217794
    oldking
    Help: 162
    Rate: 524
    Read the catalog notes of these links and you will know if you can swap them.
    Essential maximum discharge current.
  • #3 16218383
    vesperos
    In 25r there is a higher discharge current than 15l. Is this only important when choosing a replacement? What about charging? Will the charger charge properly?
  • #4 16218636
    oldking
    Help: 162
    Rate: 524
    Charging will take longer.
  • #5 16219215
    vesperos
    This is not a problem if it goes hand in hand with a longer duration of action.
