Audi a3 2001 - Constant voltage in the cigarette lighter after the ignition is t
genkowski1 8448 4
  • #1 16725113
    genkowski1
    Rate: 23
    I have such a problem, the voltage in the lighter remains even after removing the key from the ignition switch, which may be a problem or otherwise how to remove it. I bought a car camera and I need to make sure that the voltage in the lighter goes out after turning off the ignition
  • #2 16725149
    qwertexx
    Help: 11
    Rate: 44
    There is probably constant voltage in the lighter socket in A3, I have the same in golf 4
  • #3 16725204
    genkowski1
    Rate: 23
    This is not a good solution if you have a camera. I bought a cigarette lighter splitter and I think I will use it separately after ignition and leave it in the original one as is.
  • #4 16726569
    Ireneo
    Help: 746
    Rate: 2461
    If you have a camera permanently, you hide the wires and power from the box after the ignition and not the topic in this forum. Or the modification of the power socket.
  • #5 16727143
    genkowski1
    Rate: 23
    I solved the topic by attaching to the cable plus after the ignition switch from the fuse box and installing a separate splitter previously purchased, all secured with a 7.5A fuse, which I will show in the pictures. Thanks for the hints.
    • Audi a3 2001 - Constant voltage in the cigarette lighter after the ignition is t 20170928_125431.jpg (575.78 KB) You must be logged in to download this attachment.
    • Audi a3 2001 - Constant voltage in the cigarette lighter after the ignition is t 20170928_125412.jpg (481.73 KB) You must be logged in to download this attachment.
