Audi A3 8P 2003 rear light - No voltage in the rear right light bulb position
Adam_W32 21813 5
  • #1 16785282
    Adam_W32
    Rate: 55
    Hello !!!
    I have this story in the Audi A3 8P 2003 I had a burnt position light bulb in the rear right lamp. I changed the bulb and it only comes off with 0.4 Volt voltage on the contacts. The transition between the lamp and the plug is. I was looking for fuses but there are no such fuses from the rear light. There is a fuse from the light relay but all the other lights are on. Please help friends because I don't know why
    even start?
  • #2 16785294
    witek271
    Help: 19
    Rate: 174
    Vagiem scan may have a short to ground or fuse 22 somewhere
  • #3 16785681
    Adam_W32
    Rate: 55
    Fuse No. 22 (40A) good; my scanner does not reach the lights.
  • #4 16785972
    Aimshot
    Check with a current tester whether current is flowing to the position bulb. If anything flows, there is a problem on the fuses.
    Recently, the conductive module cracking in the lamp itself is popular, I would see a problem there.
  • #5 16786333
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    As in this model there is a lighting controller (displays a burnt bulb on the fis), it will not give voltage on the bulb with incorrect power, the rear positional is to be 10W, as you put in 5W, it will not light up
  • #6 16935106
    Adam_W32
    Rate: 55
    I drove 5 W bulbs and it was OK.
    However, the problem was solved with the help of the Vag scanner, I entered the option "Electr. Module" and there was an error after it was deleted, the light bulb came on. Thanks for the hints. Regards
