Audi A3 2002 1.6 16V: Dipped Headlights Not Working Despite New Switch, Relays, Fuses
22095 10
Why do the dipped headlights on an Audi A3 2002 1.6 16V have no voltage at the bulb plugs even after replacing the light switch, relays and fuses?
Check whether voltage actually reaches the dipped-beam fuses and inspect the fuse-holder/light contacts for burning, because the fault is likely in the power path before the bulbs [#16579800][#16579725] The forum also noted that on this car the voltage should be present at the fuses, since they are directly after the switch and before the control module [#16583658] A wiring diagram and a test lamp were recommended, because VAG-COM is unlikely to pinpoint this kind of basic lighting fault [#16579836] One user also reported that fuses 20/21 affect the cluster display, while pulling rear-light fuses 22/23 makes the front lights go out and triggers the dipped-beam warning, so those fuse positions are worth checking in the circuit [#16583827]
  • Low beam circuit has no voltage at bulb plug
    #1 16579664
  • #2 16579725
    Gunslinger
    Level 30  
    Help: 114
    Rate: 461
    Burned grip contacts?
  • #3 16579800
    milejow
    Help: 1564
    Rate: 5155
    Is the voltage on the fuses passing?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #4 16579836
    ociz
    Help: 1379
    Rate: 3488
    Askaniusz92 wrote:
    Nothing else related to electrics shows.
    You probably forget that it's VAG. With a computer for primitive installation ...
    The diagram, control lamp and nothing more is needed to find the fault.
  • #5 16579854
    DiZMar
    Help: 2894
    Rate: 6676
    He already wrote in the subject that everything checked . I don't know what advice I expect if there is nothing to check 8-O
  • #6 16583239
  • #7 16583583
    ociz
    Help: 1379
    Rate: 3488
    What are your bulbs in your headlights? Do you have bulb controls (indicator on clocks)?
  • #8 16583658
    adam7009
    Help: 656
    Rate: 1636
    whatever the voltage on the fuses must be, because they are in front of the control module, directly after the switch
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #9 16583827
  • #10 16583922
    polmar
    Help: 38
    Rate: 220
    Have you changed the main switch ??
  • #11 16583961
The discussion revolves around a persistent issue with the dipped headlights on a 2002 Audi A3 1.6 16V, where the user has already replaced the switch, relays, and checked fuses without success. The VAG-COM diagnostic tool indicates a problem with the main relay J271, but no voltage is present at the bulb plug when switched to low beam, although both bulbs function on high beam. Suggestions include checking for burned grip contacts, ensuring voltage at the fuses, and verifying the wiring through the steering wheel switches. The user confirmed the use of Osram H1 bulbs and noted that pulling certain fuses affects the dashboard indicators, but the issue persists despite cleaning and reinstalling the original switch.
