SONY 49XE9005 vs Samsung UE55MU7002: Comparing TV Models, Features, and Android Performance
artur5272 2907 3
  • #1 16727975
    artur5272
    Hello, I have a dilemma over these two models SONY 49XE9005 or UE55MU7002, in general I was always focused on Samsung but I did not receive a clear answer regarding the back cover whether it is possible to stick it. Maybe someone will dispel my doubts, I will be happy to listen to and consider your other TV suggestions. My budget is max 5,000.
    Maybe someone will tell me how the android behaves in this sonorah because when I read the reviews it often rains that it is muddy.
  • #3 16729974
    Ludwik XVI
    Help: 1325
    Rate: 788
    The Xe9005 is a better TV than the Samsung MU7000.
    With the fact that size also matters and you should always take it into account.
  • Sony KD49XE9005 motion stutter and slow Android issue
    #4 16750510
    mario3460
    WELCOME, I have been kd49xe9005 for about 2 months and I will say yes, the picture is very sharp, overall great, but I have a problem with this TV, i.e. when it comes to the picture, and precisely about the smoothness, the picture frames and stutters in motion, no matter if you watch TV with satellite. whether you tube or movies from the disk the image is caging there is no smooth movement I reported to sony was the service technician looked he played with the remote control and said that I am right the problem is also said that he had the same problem with the same tv with another guest and he suspects the fault lies with the tv software
    he told me to wait for updates, of course, sony does not know when it will be and in fact I do not know if they will fix this problem, I am waiting now for a response from sony what is he going to do with it
    I, however, will report it to the service again and if the service does not remove this defect or maybe my TV's defect, the case is referred to the consumer department and to the court
    after that the remote control works poorly, you need to direct it to tv because otherwise it does not work and generally tv works quite slowly what, as the service technician said, the reason is android ha think carefully or test tv exactly in the store greetings
