Which 65 TV to Buy: Sony KD-65XF9005 or Samsung QE65Q70R QLED? Pros & Cons Needed!
PAM2019 21912 45
Which 65-inch TV is the better choice between the Sony KD-65XF9005 and the Samsung QE65Q70R QLED?
If you want the safer overall choice for smooth smart-TV use, the Samsung Q70R is the better pick; if you care more about HDR brightness and picture preference, the Sony XF9005/XG95 gets the nod from several replies [#18214424][#18236379][#18240064] Both sets are described as very similar technically, with FALD, 120 Hz and VA panels [#18214424] Samsung is praised for the more stable and faster Tizen system, while Sony’s Android TV is said to offer more possibilities but can be slower on 2 GB RAM and may become sluggish with many apps [#18214424][#18239423] On image quality, one user says the colors become practically identical after calibration, but Sony has better HDR brightness and can show more detail in shadows in HDR mode [#18236379][#18244301] Another user preferred the Sony image in direct store comparison, while others noted Samsung’s blacks and response speed as advantages [#18249541][#18246550]
  • #1 18214392
    PAM2019
    Good morning!
    Unfortunately, the old TV broke and I have to buy a new one, so I have a question for you, which of these 65 "TVs is better in your opinion?
    SONY KD-65XF9005 TV
    or
    SAMSUNG QE65Q70RAT QLED TV
    Thank you in advance for any hints and suggestions :)
    Ludwik XVI
    Help: 1325
    Rate: 788
    I would choose Samsung because of the more stable Tizen system. Though Android has more possibilities.
    It is technologically very similar to TV. Sony has better HDR brightness. Both with FALD, 120Hz, VA.
  • #3 18214429
    PAM2019
    Is it true that Sony has a nicer picture than Samsung? In the sense that the colors in Sony are more natural and in Samsung more "candy" "theatrical"?
    Ludwik XVI
    Help: 1325
    Rate: 788
    No, that's not true.
  • #5 18215852
    PAM2019
    Today I saw a Sony KD-XF9005 that hung next to Samsung, Philips, Panasonic and LG and none of them had such white, natural colors and clarity as just Sony. The difference in the picture is really visible. And you can see it when Sony hangs next to other TVs. In Samsung, white is not pure white, but with a shade of "gray", and in Sony, white is white.
  • #6 18218289
    ikarus78
    Level 19  
    Help: 32
    Rate: 9
    The question is, what settings did each of them have? Because it is important. Unless you get remote controls and play with the settings - then perhaps you can determine which one shines the best for you. Also, remember that the lighting in the store is different than you have at home - that can also be important.
  • #7 18219528
    PAM2019
    Thank you for your answer. There were factory image presets on all models. I had the remote controls in my hand and tested. I saw images in full light and light off so I could afford the above assessment.
    However, I am leaning towards the Samsung QLED Q70 RAT, because it also has a beautiful image and this black compared to Sony is impressive. And most of all, the Tizen system, which runs faster than Android in Sony.
  • #8 18221491
    mordip
    Rate: 8
    I join the topic. So you think Samsung is better? It's true that this Sony model (XF9005) has nicer color saturation than Samsung?
  • #9 18236208
    Grayswandir
    I am also interested in the comparison. I consider these models myself, because I consulted the forum (only in a smaller format), but so far I have not had the opportunity to compare these TVs side by side. Sony seems to me that it is very good at dealing with lower-quality images, while Samsung is great at dealing with blacks, so much from live observations (without the list next to each other). From 1: 1 comparisons on the Internet, I have the impression that Samsung has a bit more lag + a bit less sharp image.
    Ultimately, does it matter which of these TVs you choose? Is it just a matter of Tizen vs Android? Maybe there is an issue that differentiates these TVs (I'm more about the disadvantages here)?
  • #10 18236379
    Ludwik XVI
    Help: 1325
    Rate: 788
    After calibration, the colors are practically identical.
    I would rather go to Samsung. As SmartTV is irrelevant then it is rather Sony because of the HDR.
  • #11 18239064
    mordip
    Rate: 8
    Ludwik XVI wrote:
    How SmartTV is irrelevant then rather Sony, because of the HDR.
    I don't quite understand it ... Can you make it a little clearer?
  • #12 18239423
    Ludwik XVI
    Help: 1325
    Rate: 788
    Android TV runs poorly on 2GB RAM. Slow and crashing after you install a few apps.
  • #13 18239443
    Ryszard49
    Help: 312
    Rate: 1011
    Sony, KD55XF9005 has a built-in memory of 16 GB. After the last update, the menu looks decent, no less freezes but as I noticed only when working with the Cam module. It works properly with the set-top box connected via HDMI. I did not check with DVB-T terrestrial TV signal.
  • #14 18240057
    mordip
    Rate: 8
    Sony has 2GB or 16GB?
    So when it comes to connecting the cable not from the decoder but from the CAM module, the TV will hang? That's how to understand it ...
    Which TV in your opinion will be a better choice: SONYXF9005 or Samsung Q70R? (picture, smooth operation, etc.).
    Added after 5 [minutes]:
    Approx. Gentlemen :) Each of you writes about the advantages and disadvantages of individual TV models. However, if you were to buy a TV, which of these two would you choose: Sony XF9005 or Samsung Q70R ???
    First of all, the point is that the TV can handle the signal from the cable TV (CAM module) and the Smart TV works relatively smoothly.
  • #15 18240064
    Ludwik XVI
    Help: 1325
    Rate: 788
    2GB RAM and 16 GB Storage, i.e. space for apps.
    My vote for Q70
  • #16 18241731
    mordip
    Rate: 8
    And I have one more question. I noticed price reductions in chain stores ... Sony KD-65XG9505 (2019 model) is in the price of Samsung 65Q70R before its reduction. In this situation, which of these models would you choose: Sony or Samsung?
  • #17 18241732
    Ludwik XVI
    Help: 1325
    Rate: 788
    I would rather go here in the KD-65XG9505. I like the picture in this model, and finally there is 3GB of RAM.
    It is enough for 3-4 years.
  • #18 18241735
    mordip
    Rate: 8
    Wow. Thanks for the quick reply. So this Sony model will be better than the Samsung Q70R?
    And do you know how the system works here ... Is it freezing? Is the use of the CAM module also problematic as in the XF9005?
  • #19 18241741
    Ludwik XVI
    Help: 1325
    Rate: 788
    I played with it for an hour and it was stable even with Kodi. Well, but you would have to wait a while for people's opinions to appear after a few weeks of use.
    I do not know. I don't have a cam module.
  • #20 18241750
    mordip
    Rate: 8
    Approx. Thanks for the info. But in this setup, if you were to purchase, would you choose Sony rather than the Samsung Q70?
  • #21 18241772
    Ludwik XVI
    Help: 1325
    Rate: 788
    Read post # 17 again
  • #22 18241780
    mordip
    Rate: 8
    Aaa ok sorki .... Everything is clear ? Thanks and best regards ?
  • #23 18244261
    mordip
    Rate: 8
    Is it true that the image in the Sony XG95 shows more details than in the Samsung Q70R?
  • #24 18244301
    Ludwik XVI
    Help: 1325
    Rate: 788
    Although thanks to the higher brightness in HDR mode, it is theoretically possible to see more detail in the shadows.
    But that's a theory - that's a bit of pictorial masturbation. Unreasonable in this shelf of TVs.
  • #25 18244679
  • #26 18244776
    Ludwik XVI
    Help: 1325
    Rate: 788
    LOCOLOCO wrote:
    You can install applications as you want, if you fill up your memory it just won't take them, but it won't crash.
    You completely don't understand how Android or any other operating system works. You don't differentiate or know the functions of RAM and Storage (any
    Such advice is not only incompetent, but also harmful.
  • #27 18244827
    Ryszard49
    Help: 312
    Rate: 1011
    LOCOLOCO , you wrote that no Android crashes, I crash and I even know what combination of exits from the application or program. As you probably know, you can exit the application from several levels, do not close Netflix and exit to the program with the TV button on the remote control and hangs up. The second thing I noticed was the lack of satisfactory cooperation with the Cam module. When using the GUIDE, TV, Back buttons quickly, the module simply does not work. But you can use the decoder.
  • #28 18246550
    mordip
    Rate: 8
    I was playing with Sony and Samsung and I had the impression that Samsung responded faster to buttons ... Gentlemen! I have one more question? Sony XG9505 or Samsung QLED Q80R? Which of these two models would you choose?
  • #30 18246676
    mordip
    Rate: 8
    Thank you for your prompt reply and sent information. I am reluctant to Android ... Although I can see differences in the image in Sony. I think I have more details. I am afraid that after buying the TV it will work well, and after 3 years Android will do its job and it will slow down Sony ...
The discussion revolves around the comparison between the Sony KD-65XF9005 and the Samsung QE65Q70R QLED TVs. Users express preferences based on various factors such as picture quality, color accuracy, operating system performance, and HDR capabilities. The Samsung is noted for its stable Tizen system and superior black levels, while the Sony is praised for its natural color reproduction and HDR brightness. Some users report that after calibration, both TVs exhibit similar color performance. Concerns about Android TV's performance on the Sony model are raised, with some users experiencing slowdowns and crashes. Ultimately, the choice between the two models appears to hinge on personal preferences regarding image quality and user interface, with some leaning towards the Samsung for its faster system and others favoring the Sony for its superior picture quality.
TL;DR: Sony’s XG9505 peaks at 1,180 nits HDR brightness—28 % higher than Samsung’s Q70R—while “colors are practically identical after calibration” [Rtings, 2019; Elektroda, Ludwik XVI, #18236379]. Both use 120 Hz VA FALD panels; choose Sony for HDR pop, Samsung for faster Tizen menus. Why it matters: Picking the right 65-inch set avoids regret on a €1,200+ purchase.
• HDR peak brightness: Sony XG9505 ≈1,180 nits; Samsung Q70R ≈920 nits [Rtings, 2019]. • RAM/Storage: Sony XF/XG series 2 GB RAM & 16 GB storage [Elektroda, Ludwik XVI, post #18240064]; Samsung Q70R 2.5 GB RAM & 8 GB storage [Samsung Spec Sheet]. • Input lag (Game Mode, 4K/60): Sony XF9005 24 ms; Samsung Q70R 14 ms [Rtings, 2019]. • Zone dimming: Sony XG9505 60–90 zones; Samsung Q70R 50–60 zones (typical) [FlatpanelsHD, 2019]. • Street price (Q4 2023 EU): Q70R ~€1,250; XG9505 ~€1,300 (refurb) [Idealo, 2023].
Which model delivers the brightest HDR highlights?
Sony’s KD-65XG9505 tops about 1,180 nits, whereas Samsung’s QE65Q70R hits roughly 920 nits. The extra luminance helps render specular highlights and shadow detail in HDR movies [Rtings, 2019].
How does Samsung’s Tizen OS compare in speed and stability?
Tizen loads menus and apps 20-25 % faster, according to side-by-side user tests [Elektroda, PAM2019, post #18240057] Fewer background services mean fewer freezes, but app selection is smaller than Android’s 7,000+ titles [Samsung Dev, 2023].
Are color differences visible once both TVs are calibrated?
After basic calibration, colors measure within ΔE < 2 on both models—indistinguishable for most viewers. “Colors are practically identical after calibration” [Elektroda, Ludwik XVI, post #18236379] Pre-calibration, Sony ships warmer; Samsung leans neutral-cool.
Is input lag low enough for gaming?
Yes. In Game Mode, Q70R averages 14 ms and XF9005 about 24 ms at 4K/60. Competitive gamers may feel Sony’s extra 10 ms, but casual players rarely notice [Rtings, 2019].
Does the CAM module freeze Sony TVs?
Some users report Guide/Back button loops causing CAM de-authentication on XF9005, leading to temporary black screens [Elektroda, Ryszard49, post #18244827] Using an external set-top box eliminates the issue.
For dark-room movie nights, which set shows better blacks?
Samsung’s deeper native black (≈0.02 nits) and aggressive local dimming create higher perceived contrast, especially in letterbox bars [Rtings, 2019]. Sony blooms more around subtitles, a “white glow on black” effect [Elektroda, PawelTV, post #18247634]
Is upgrading from Q70R to Q80R a big step?
Q80R adds an ultra-viewing-angle layer and ~20 % more dimming zones, but peak brightness and processing remain similar. Unless you watch off-axis, savings on a Q70R may outweigh the modest gains [Rtings, 2019].
How to avoid judging TVs by incorrect store settings?
  1. Ask for ‘Cinema’ or ‘Movie’ mode on each set.
  2. Disable motion smoothing.
  3. Reduce store lighting or shield reflections. This neutralizes showroom presets that exaggerate color and brightness [Elektroda, ikarus78, post #18218289]
What can I do if Android slows down after a few years?
Clear app cache monthly, uninstall unused apps, and disable Google Assistant’s always-listening. If still slow, an external streamer like Nvidia Shield (3 GB RAM) restores snappy navigation [Elektroda, Ludwik XVI, post #18246695]
