Best 2.4GHz 8-Channel Bait Boat Equipment with 1000m Range, Channel Mixing & Sub-PLN 1000 Options
skuwa 6153 19
How can I choose a 2.4 GHz RC transmitter with at least 8 channels, channel mixing and a real 1000 m range for a bait boat, within about PLN 1000?
A real 1000 m range over water is not guaranteed, because the usable range can drop by about 50%, so it is better to choose a radio whose manufacturer specifies 1000 m and not expect full land-range performance on the lake [#16728396][#16730934][#16731284] A practical 8-channel option mentioned was the Spektrum DX8 G2 with an AR8000 receiver or a DSM-X compatible OrangeRX receiver; if both transmitter and receiver are DSM-X, the link should reach up to about 2 km, and a long-range OrangeRX R1220XLR receiver was also suggested [#16729105][#16729419] Another budget-friendly route is the Turnigy 9XR Pro, where you can later add a module; FrSky XJT/DJT modules were specifically referenced as compatible via the Futaba trainer port using the telemetry cable [#16732036][#16752038] The Hitec Flash 8 and Aurora 9X were mentioned, but their standard receivers only provide up to 6 channels, so they do not meet the 8-channel requirement [#16728878]
  • #1 16728290
    skuwa
    Hello. It turns out that I am new to the forum - I haven't logged in for a long time and it looks like my profile has been deleted (small losses :) )
    Moving on to the topic:
    I'm planning to build a bait boat,
    I am looking for 2.4Ghz apparatus, about 8 channels and a minimum range of 1000m
    The equipment should have channel mixing - finally I can connect an external mixer
    Anyone recommend something?
    Price up to PLN 1000?
  • #3 16728477
    skuwa
    Maxima 6 probably falls off because it needs digital servos, and they cost a little and I will need a few pieces (about 4 or two, minimum 10kg)
    Later, the boat will be equipped with a Toslon X-Pilot and a Toslon sonar
    PS.
    If I am burning some blunder, please be understanding because I am just starting with RC and this will be my first construction
  • #4 16728878
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3631
    But for HiTec Flash 8 and Aurora 9X transmitters, you can use OPTIMA and MINIMA standard receivers (with analog output) - only max 6 channels.
  • #5 16729069
    skuwa
    I need 8 channels minimum
  • #6 16729105
    tzok
    Help: 3175
    Rate: 6546
    Maybe the Spektrum DX8 G2 and the AR8000 receiver or the DSM-X compatible "trip" from OrangeRX (eg R820X V2)?
  • #7 16729361
    skuwa
    They write differently about spectrum DX8 when it comes to range.
    What do you think of the futaba t10?
  • #8 16729419
    tzok
    Help: 3175
    Rate: 6546
    They write differently because there is DX8 (DSM-2) and DX8 G2 (DSM-X). If there is a DSM-X apparatus and a DSM-X receiver, it should "stretch" up to 2km. There are also "rugged" receivers for long-range control, such as the OrangeRX R1220XLR.
  • #9 16730371
    skuwa
    How about the futaba 8fg or Futaba 10J app?
  • Futaba range should be satisfactory on water
    #11 16730730
    skuwa
    1 PAWEL wrote:
    Rather, some useful tests to read
    https://www.google.pl/search?num=100&newwindo...j0i22i30i19k1l7j0i22i10i30i19.04.319.0i19.011. 159.443.0j3.3.0.dummy_maps_web_fallback ... 0 ... 1.1.64.psy-ab..0.3.441 .... 0.y096P7THHgc
    From what I have read, people highly recommend futabe in general.
    I just mean whether the range will be satisfactory on the water
  • #12 16730934
    1 PAWEL
    Help: 674
    Rate: 1364
    On the water, for various reasons, the apparatus sometimes loses 50% of its range,
    anyway, it's interesting what you will see from a distance of 500 meters with the boat size of about 70 cm.
  • #13 16731076
    skuwa
    Ultimately, the boat is to be equipped with a Toslon TF640 GPS sonar and Toslon x-pilot autopilot
    The lake on which I am going to swim is 80 km of the shoreline
  • #14 16731284
    1 PAWEL
    Help: 674
    Rate: 1364
    Standard apparatus is enough where the manufacturer specifies a maximum range of 1000 meters.
  • #15 16731430
    skuwa
    Can you advise something more specific?
    Tgy 9x? - what module to buy?
  • #17 16733474
    skuwa
    1 PAWEL wrote:
    OK, and which module would be the best for this app from hobbyking.com? - I need as many channels as possible
    Do I need these cables for telemetry?
    https://hobbyking.com/en_us/frsky-telemetry-head-track-module-extent-cable-for-9xr-pro.html
  • #18 16752038
    1 PAWEL
    Help: 674
    Rate: 1364
    Opis
    This cable make FrSky telemetry data "plug and play" with the Turnigy 9XR-PRO, via the Futaba trainer port. However the “Y” lead lets you still access the Futaba trainer port at the same time for head tracking or other ppm devices.
    Compatibility: 9XR Pro to Frsky XJT or DJT modules
  • #20 16759517
    1 PAWEL
    Help: 674
    Rate: 1364
    You don't know how much the range will drop above the water, but if you really care about the range
    you can buy an additional module at any time after checking if it will be needed.
The discussion revolves around selecting suitable 2.4GHz equipment for building a bait boat with at least 8 channels and a range of 1000m, while also considering channel mixing capabilities. Users recommend various transmitters and receivers, including the HiTec Flash 8, Aurora 9X, Spektrum DX8 G2, and Futaba models. Concerns about range loss over water and the need for digital servos are raised. The Turnigy 9XR Pro is suggested as a potential option, along with inquiries about compatible modules for extended range. The conversation highlights the importance of understanding the specifications and compatibility of the equipment for optimal performance.
TL;DR: Expect up to 50% range loss over water; “On the water, the apparatus sometimes loses 50% of its range.” Ideal for anglers building bait boats who need reliable 2.4 GHz control and clear upgrade paths. [Elektroda, 1 PAWEL, post #16730934]
Why it matters: Water kills signal and line‑of‑sight—picking gear with realistic range and channel capacity avoids lost boats and wasted money.
What range can I realistically expect over water with 2.4 GHz?
Plan for roughly half the dry‑land range. Water and low antenna height attenuate the signal, and small hulls vanish visually near 500 m. Keep antennas high and maintain line‑of‑sight. This conservative budget helps prevent failsafes during bait drops. [Elektroda, 1 PAWEL, post #16730934]
Is a 1000 m control distance realistic for a bait boat?
Treat 1000 m as marketing on water. As one expert noted, “1000 meters above the water is rather unreal.” Design your route and drop points within a safer envelope to reduce loss‑of‑link risk. [Elektroda, 1 PAWEL, post #16728396]
Which 8+ channel radios did users recommend in the thread?
Hitec Flash 8 and Aurora 9X were suggested as solid 2.4 GHz options. Download and review the manuals before purchase to confirm mixing, failsafe, and receiver compatibility for your setup. [Elektroda, 1 PAWEL, post #16728396]
Do Hitec Flash 8/Aurora 9X support analog receivers?
Yes. They work with Hitec OPTIMA and MINIMA standard receivers that provide analog outputs, but you’ll be limited to a maximum of six channels with those receivers. [Elektroda, kotbury, post #16728878]
I need at least 8 channels—what alternative was proposed?
Consider a Spektrum DX8 G2 paired with an AR8000 receiver or a DSM‑X‑compatible OrangeRX (e.g., R820X V2). Verify failsafe behavior and antenna placement for long runs on water. [Elektroda, tzok, post #16729105]
How far can DSM‑X go for long‑range control?
With DSM‑X transmitters and DSM‑X receivers, users report stretches up to about 2 km. Rugged long‑range receivers like OrangeRX R1220XLR further harden the link. Always validate at your venue before pushing distance. [Elektroda, tzok, post #16729419]
Are Futaba 8FG or 10J good picks for water use?
Users often recommend Futaba for reliability, but range over water still depends on conditions and antenna placement. Read independent tests and plan for signal loss when operating near your limit. [Elektroda, skuwa, post #16730730]
Does the Hitec Maxima 6 require digital servos?
Yes. Maxima 6 receivers expect digital servos, which can raise costs if you need several high‑torque units for doors or steering. Budget accordingly when planning 8‑channel builds. [Elektroda, skuwa, post #16728477]
Is a standard 1000 m‑rated radio enough for bait boats?
It can be. If the manufacturer specifies a maximum range of 1000 m, a standard set often suffices for typical baiting missions when operated prudently. Stay within visual control. [Elektroda, 1 PAWEL, post #16731284]
What module should I use with a Turnigy 9XR Pro?
9XR Pro requires an external JR‑bay module. A practical path is FrSky XJT or DJT, and you can add telemetry plug‑and‑play using the referenced cable for the trainer port. [Elektroda, 1 PAWEL, post #16752038]
Is moving to 900 MHz (e.g., FrSky R9M) worth it for water range?
Test first with your standard 2.4 GHz setup. If you truly need more distance, buy the long‑range module later. “You can buy an additional module at any time after checking if it will be needed.” [Elektroda, 1 PAWEL, post #16759517]
Do I need a special telemetry cable on the 9XR Pro?
For FrSky XJT/DJT modules, the listed Y‑cable makes telemetry plug‑and‑play via the Futaba‑style trainer port, while keeping trainer features available. [Elektroda, 1 PAWEL, post #16752038]
How should I test range safely before long bait runs?
  1. Verify link on shore and perform a gradual distance walk‑test.
  2. Water‑test in clear line‑of‑sight, antennas vertical and high.
  3. Only then consider upgrades if range proves insufficient. “Buy an additional module after checking if it will be needed.” [Elektroda, 1 PAWEL, post #16759517]
What onboard electronics are people pairing with these radios?
Builders mention Toslon TF640 GPS sonar and the Toslon X‑Pilot autopilot for precise routes and waypoint drops on large lakes. Ensure channel budgeting covers steering, doors, lights, and autopilot control. [Elektroda, skuwa, post #16731076]
