Electrolux ENN12800AW fridge - how to glue a broken drawer in the freezer
sebry 10506 3
  • #1 16729527
    sebry
    Rate: 11
    The drawers in the Electrolux ENN12800AW fridge-freezer freezer have cracked / broke, hence the question about the material from which they are made and the adhesive that sticks them (I was thinking about giving a patch of the same material at the point of crack). Maybe someone has some experience in this topic (such a drawer costs PLN 150 and I have two broken ones).
    best regards
  • #2 16729559
    wik12
    Help: 8
    Rate: 30
    I take drawers that scrap metal. There is a lot after collection and segregation of dimensions. I have welded a few as if it had burst but on a thicker scale it doesn't pay off. Plastic for plexiglass, if I remember correctly, it means OO marking and where you don't have to do it, don't print it. I'll put a hot air soldering station.
  • #3 16731636
    sebry
    Rate: 11
    For me it is important what material these drawers are because in this way I will choose the right adhesive - I saw on the Internet materials as adhesive plastic cracks for a "patch" and such a connection is stronger than the original.
    best regards
  • #4 16802043
    sebry
    Rate: 11
    Hello. Problem solved - I bought plexiglass 2mm thick, cut into pieces and glued making patches with Acrifix 1s 0116 glue. Now the drawers are stronger than new, a month in the freezer and the glue holds. best regards
