Samsung RB37J5315SS Fridge Door Dent Repair: DIY Methods or Door Replacement Options
OlekPek 24171 2
  • #1 16809508
    OlekPek
    Rate: 17
    Well, as in the topic, I have a brand new fridge Samsung RB37J5315SS . Unfortunately, a small accident happened and the phone flying (fell out of hand ...) hit the door, bounced off the floor and hit it the second time. Interestingly, the phone is not even scratched. Well, but there were very visible dents (one is in the middle, the other just above the floor ... both of them can be clearly seen in the sunlight):
    I tried to remove them using the heat / cold method. I have the impression that it helped a little but it still remains what you see in the picture. Is it possible to fix it somehow? Because you can see it terribly, and the fridge is brand new. On the Internet, they wrote about the possibility of changing the door, but that's when there are additional costs of at least PLN 400. Thank you in advance for your help.
  • #2 16809609
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    Try a pops-a-dent can make a good movie on YouTube though it's meant for the bodywork but it's a similar thing :D Set about 20pln.
  • #3 16811208
    OlekPek
    Rate: 17
    Thanks :D I will try to try as soon as possible and report :D
