Schwarzbau ZBV100 Oil Compressor Review: 100L, 2 Pistons, 440L/min - Suitable for Garage & Hobby?
badziu85 7467 2
  • Questioning whether the ZBV100 suits hobby garage use
    #1 16732346
    badziu85
    Hello all.
    I figured out:
    OIL COMPRESSOR ZBV100 SCHWARZBAU
    100L, 440L / MIN
    Maybe someone uses this model and can say something if it is worth buying such equipment for garage and home needs. Like blowing out, painting small parts, pneumatic screw wrench on a passenger car. I will be using it on the weekend for private purposes - as a hobby.
    This is its specification from the online store.
    Manufacturer
    Schwarzbau
    Model
    ZBV100
    Max power consumption
    3300W
    Engine working power
    2.2kW
    Suction performance
    440l / min
    Working performance
    316l / min
    Cylinder capacity
    100l
    Engine revolutions
    2850r / min
    Power
    230V
    Volume
    97dB
    Working pressure
    8bar
    Safety valve
    8.5bar
    Degree of engagement
    6bar
    Piston diameter
    2x47mm
    Device weight
    about 50kg
    Lubrication
    Oil
    Oil used
    Compressor
    Compressor drive
    direct
    Engine type
    inductive
    Built-in pressure reducer
    Yes
    • Schwarzbau ZBV100 Oil Compressor Review: 100L, 2 Pistons, 440L/min - Suitable for Garage & Hobby? E1F0213C-FFC3-4275-B8EC-0947C35EE9BD.jpeg (766.8 KB) You must be logged in to download this attachment.
  • #2 16757934
    wnoto
    Help: 58
    Rate: 745
    It's enough for such applications.
    What price ?
