- Installing Generic Phone Drivers for Old Nokia from a .cab File Without Internet Access
indigoplateau 7191 12
How can I install Nokia phone drivers from a CAB file on Windows 7 without internet access?
Extract the CAB or driver package with 7-Zip, WinZip, or the expand command, then install the driver manually from Device Manager by browsing to the extracted files instead of trying to run an installer [#16733150][#16733526] If the device is detected as a generic phone, use its hardware ID from Device Manager to match the correct Nokia driver; in the thread the device IDs were NMWCD\VID_0421&PID_028f with several interface variants [#16733177][#16733484] The working package mentioned was Nokia-Allx64-Cable-drp.exe, which should be opened/extracted with 7-Zip, and the EXE itself should not be run [#16733526] After selecting the extracted drivers through Device Manager, the original poster reported that it worked [#16733716]
  • #1 16733137
    indigoplateau
    Hey!
    I need help installing drivers from a .cab file.
    These drivers are "generic phone" for old nokia.
    I don't have internet on my computer and that's why I downloaded it manually.
    The problem is that this .cab file does not contain any installer, .exe file.
    I also fail to install these drivers through the device manager.
    And that means: device manager> other devices> generic phone> update driver software.
    It then displays that "the system cannot find the driver software for this device".
    I found the tutorial "steps to install .cab file in windows 7 or 8".
    But it's written in a way I don't understand, and in English.
    Please help.
  • #3 16733150
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Unzip the cab file, e.g. with WinZip etc. or use the expand command.
  • #4 16733172
    indigoplateau
    The phone is nokia 2007 classic and windows 7.
    But I immediately unpacked this .caba and hence I know that there is no installer in it.
  • #5 16733177
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Enter the ID of this phone from the device manager (pid and vid).
  • #6 16733223
    indigoplateau
    There is none.
    There is only "generic phone" and some "unknown devices" in other devices.
    And when I connect a phone via usb to a computer it shows that "the failure to install the device driver software".
    And that the "generic phone" driver was not found.
  • #7 16733231
    Kasek21
    Help: 4981
    Rate: 3547
    indigoplateau wrote:
    There is none.
    What are the identifiers for these devices?
    Download and installation do not help ?: Nokia PC Suite 7.1 PL
  • #9 16733234
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Do not invent, just enter your phone ID! If it detects as a "generic phone" then enter its identifier.
    https://www.elektroda.pl/rtvforum/topic1228905.html
    It is best to provide identifiers for all devices for which drivers are missing, as well as provide system versions.
  • #10 16733484
    indigoplateau
    NMWCD\VID_0421&PID_028f&IF_OTH
    NMWCD\VID_0421&PID_028f&IF_OBX
    NMWCD\VID_0421&PID_028f&IF_Cdc_Modem
    NMWCD\VID_0421&PID_028f&IF_JAVACOMM
    NMWCD\VID_0421&PID_028f&IF_LC
    A system to windows 7 professional.
  • #11 16733496
    Kasek21
    Help: 4981
    Rate: 3547
  • #13 16733716
    indigoplateau
    It worked, MANY thanks! :)
    @ Kasek21 from here this topic.
    I used this program to be able to connect to the internet from a telephone.
    But now something is broken, it started to show that "the phone is connected in an incompatible usb mode".
    This removed the phone from the device manager and reinstalled the nokia pc suite as they advised on the net.
    But this problem with the drivers appeared and that's why I came here in the forum.
    To close.
The discussion revolves around the installation of generic phone drivers for an old Nokia model (Nokia 2007 Classic) from a .cab file on a Windows 7 system without internet access. The user faced challenges as the .cab file lacked an installer and attempts to update the driver via Device Manager resulted in errors indicating that the driver software could not be found. Participants suggested unzipping the .cab file and entering the device identifiers (PID and VID) to locate the correct drivers. A helpful response provided a link to download an executable file that, when unzipped and used in Device Manager, successfully installed the necessary drivers. The user confirmed the solution worked but later encountered a new issue regarding USB mode compatibility.
TL;DR: Fix old Nokia “Generic Phone” drivers offline with a 3‑step method; “Do not run the exe file.” [Elektroda, Kolobos, post #16733526]
Why it matters: You can get a legacy Nokia online or tethered without internet on the PC, using only local files.
How do I install Nokia “Generic Phone” drivers from a .cab without internet?
Extract the driver pack locally, then point Device Manager to the INF. Use 7‑Zip to unpack the recommended Nokia driver archive, and install via Update Driver in Device Manager. Do not run the exe; install by browsing to the extracted folder. This three‑step workflow fixed the thread case offline. [Elektroda, Kolobos, post #16733526]
The .cab has no .exe. How do I proceed?
Unpack the .cab using WinZip or the Windows expand command. Then, in Device Manager, choose Update Driver and Browse to the extracted folder that contains INF files. Windows will match the correct INF to the hardware ID and install. [Elektroda, Kolobos, post #16733150]
Which driver pack actually worked here?
The Nokia-Allx64-Cable driver pack from DRP worked when extracted with 7‑Zip and installed via Device Manager. The key was not executing the installer, but manually selecting drivers from the unpacked files. [Elektroda, Kolobos, post #16733526]
Should I run the driver pack’s .exe or extract it?
Extract it and avoid running the executable. As the expert put it, “Do not run the exe file.” Install by selecting Update Driver, then Browse to the extracted folder. This prevents unwanted package behavior on offline systems. [Elektroda, Kolobos, post #16733526]
Where do I get the hardware IDs for my Nokia?
Check Device Manager entries tied to the phone. In the case solved here, the phone exposed five NMWCD interfaces, including IF_Cdc_Modem and IF_JAVACOMM. Matching these IDs to the extracted INF enabled installation. [Elektroda, indigoplateau, post #16733484]
Device Manager shows only “Generic Phone” and Unknown devices. What now?
That symptom indicates Windows lacks a matching driver. Point Update Driver to the extracted Nokia driver folder so Windows can resolve “Generic Phone” to the correct INF. This replaces the failed automatic search. [Elektroda, indigoplateau, post #16733137]
I still see “system cannot find the driver software for this device.” How do I fix it?
Install from a local driver source. Use Update Driver, select Browse my computer, and target the extracted Nokia driver directory. This avoids online search and satisfies the hardware ID mapping. [Elektroda, indigoplateau, post #16733137]
What does NMWCD mean and why are there multiple interfaces?
NMWCD refers to Nokia Mobile Windows Connectivity Device. Old Nokia phones enumerate several interfaces, such as modem and Java communication. In the case discussed, five interfaces appeared under one device, all needing drivers. [Elektroda, indigoplateau, post #16733484]
Will Nokia PC Suite 7.1 fix this automatically?
It can help with connectivity and tethering. However, the poster reinstalled PC Suite and still hit an “incompatible USB mode” message. If that occurs, fall back to the manual INF install from the extracted driver pack. [Elektroda, indigoplateau, post #16733716]
I get “phone connected in an incompatible USB mode.” What should I try?
Remove the phone from Device Manager, reinstall Nokia PC Suite, and then reinstall drivers from the extracted pack. This sequence resolved recognition issues reported in the thread. [Elektroda, indigoplateau, post #16733716]
Can I use WinZip or the expand command on .cab files for this?
Yes. Unzip the .cab with WinZip or use the expand command, then install drivers by pointing Device Manager to the INF location. This avoids needing an installer. [Elektroda, Kolobos, post #16733150]
Is this offline method safe and repeatable on Windows 7?
Yes. The process relies on local extraction and Device Manager’s Browse feature. It worked on Windows 7 Professional for a 2007 Nokia in the thread case, restoring connectivity without internet. [Elektroda, indigoplateau, post #16733484]
