Seeking OP-COM USB V2 Interface Drivers for Windows 10 64-bit, Version 1703
jacek0503 146820 11
How can I get an OP-COM USB V2 interface with VID_0403/PID_4F50 working on Windows 10 64-bit version 1703?
Use the FTDI VCP drivers and add your device ID to the INF file; Kolobos said the drivers are on the FTDI website and that the INF must be modified with your VID/PID [#16605978] He then provided a prepared INF in an attachment and later said to use the INF from that file and replace it with your own IDs [#16606027] [#16606073] He also noted that a Windows 7 x64 driver should still work on Windows 10 x64 [#16606073]
  • #1 16605957
    jacek0503
    Help: 28
    Rate: 175
    I warmly welcome. Please help me find drivers for the OP-COM USB V2 Interface device.
    USB / VID_0403 & PID_4F50 & REV_0600
    The system is Windows 10 version 1703 - 64 bits.
    Thank you very much for your help and best regards. J
  • #3 16606014
    jacek0503
    Help: 28
    Rate: 175
    Thank you for the drivers, unfortunately I can not modify the files - could the esteemed colleague teach me how to do it?
  • #4 16606027
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Check these from the attachment.
    • CDM v2.12.26 WHQL Certified.zip (1.6 MB) You must be logged in to download this attachment.
  • #5 16606057
    jacek0503
    Help: 28
    Rate: 175
    "Windows found drivers for this device but encountered an error installing them
    The hash for the file is missing from the specified catalog file, possibly the file has been corrupted or tampered with
    That was the answer - nothing is damn thing.
  • #6 16606073
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Maybe I've changed something.
    Use the inf file from this file: https://www.elektroda.pl/rtvforum/download.php?id=575613 and subchange with yours.
    You can also check this driver, it is under W7 64bit but it should work and under W10 64bit.
    I understand that it is an OP-COM USB V2 Interface which you obviously did not specify and that the system is 64bit?
    Ps. In case of further problems, you can always install Windows 7 under vmware and use the adapter there.
  • #7 16606102
    jacek0503
    Help: 28
    Rate: 175
    Yes - sorry, this is what my friend said - everything is correct.
    Added after 10 [minutes]:
    Unfortunately, no files will be installed, unless I have to install the previous version of the system - it is very troublesome for me and I do not know if it will be completely successful. I don't understand why they won't install these drivers.
  • #8 16606134
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    I do not know too. It will be best to install Windows 7 under VMware as I have provided, thus you will keep W10.
  • #9 16606198
    jacek0503
    Help: 28
    Rate: 175
    Thank you for your help. My colleague Kolobos is helpful as always. Be fore the enormous knowledge and kindness of my colleague. I think I solved the problem - tomorrow, if it will be ok, I will describe it for sure. If my colleague Kolobos likes beer, I have the ENTIRE TIRA of his favorite beer. Thank you and best regards. J
  • #10 16606222
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    > I think I've solved the problem
    How? We managed to install drivers?
  • #11 16606230
    jacek0503
    Help: 28
    Rate: 175
    I think it worked. Tomorrow tests and I will definitely write what and how - I will not forget it, knowing my bad luck, it follows me like ... I will write tomorrow after the tests.
  • #12 16611267
    jacek0503
    Help: 28
    Rate: 175
    Damaged equipment. He landed in the trash. I close the topic.
The discussion revolves around finding drivers for the OP-COM USB V2 Interface device compatible with Windows 10 64-bit, version 1703. Users suggest downloading drivers from the manufacturer's website and modifying the INF file to include specific USB IDs (VID_0403 & PID_4F50). Some users encounter installation errors related to corrupted files or missing hashes. Alternatives include using a driver from a different source or installing Windows 7 in a virtual machine to facilitate driver installation. Ultimately, one user reports a potential resolution but later indicates that the equipment may be damaged, leading to the closure of the topic.
