Washing machine LG F10C3LD (slim 45cm), and on it dryer 55-60cm deep
gdw 25776 5
  • #1 16733317
    gdw
    Rate: 38
    Welcome!
    We have a 4-year LG F10C3LD washing machine, the lowest model, but we are very pleased with it. We want to buy a dryer, but they are 55-60cm deep, while the washing machine has only 45cm. How to combine it together when the dryer has to stand on the washing machine? Can I set one on top of the other, do I need to build some shelf on which it will stand?
    Thank you in advance for ideas!
  • #2 16733361
    jaszczur1111
    Help: 173
    Rate: 493
    If it were the other way around ... then the washing machine would have a chance to fall down when spinning. For me, the dryer is on the Ardo WD100, but both devices are full-sized. When spinning, there are no problems, but not every washing machine is so stable. You can make a frame on which you set the dryer, but the appearance will be poor.
  • #3 16733807
    gdw
    Rate: 38
    So how do these plastic connectors work between the washing machine and the dryer? Is it screwed to the top or stuck? Maybe for such a connector I would do two legs behind the washing machine from some small steel profile painted white?
  • #4 16734653
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3368
    gdw wrote:
    the dryer must stand on the washing machine
    It does not have to, it can stand next to it, or in another room.
  • #5 16734758
    gdw
    Rate: 38
    In a small apartment with a 4-person family, he must stand on the washing machine ;) There is no where else. The dryer ordered, Electrolux with a depth of 54cm. It will come, I will be combining, it looks like the AEG / Electrolux STA8 connector will fit in if necessary.
  • #6 16764269
    gdw
    Rate: 38
    The dryer has arrived, Electrolux EDP12074PDW, one of the few models with a depth of 55cm. Fortunately, it fits on the LG F10C3LD washing machine without any connectors. All thanks to the fact that it has legs with less spacing, about 41-42cm to the depth.
    Greetings!
