[Solved] Air draft regulator for SAS furnace Damaged Afriso FR1 once again
Leon444 19617 15
Why does the air draft regulator on my SAS wood stove stop responding to temperature after a season or two, and do I need to replace it every year?
It usually stops responding because air or steam gets trapped under the regulator, not because the unit must be replaced every year [#16738769][#16742616] Check that the boiler/regulator pipe is mounted so it can vent properly; if the regulator connection is on top of the boiler, the front of the boiler should be 2–3 mm lower than the back [#16738769][#16742796] When it starts acting up, slightly loosen the regulator so the trapped air can escape until water comes out, then tighten it again [#16742616] If the installation keeps trapping air, you can shorten the pipe, add a tee as a vent, or fit a bleed screw/automatic vent to the regulator stand [#16742796][#16742740][#16742644] A tee can also improve water circulation and make the regulator react faster when the temperature drops [#16742796]
  • #1 16734201
    Leon444
    Help: 48
    Rate: 355
    I have a problem every year with air draft regulators for SAS wood stove.
    The first original Regulus regulator worked for a year and after the summer season when I wanted to start the furnace worked the first time and as if jammed it simply did not react to temperature, it remained open with the 70st setting and the furnace was almost up to 100st C and no reaction time is present .. .
    I exchanged him for Afriso a year ago and he worked beautifully, smoothly and in general this year, the same thing, the first firing beautifully, the second one he would cut, and today he almost does not react ...
    What is with these rulers? should I exchange a new one every year?
    I was thinking that he could take it apart and throw the expanding cartridge itself in the fridge, maybe it would help him change the temperature, or soak it in oil or WD40, what do you think?
    I do not want to change the regulator again, I will not replace it every year, after that I use the oven very sporadically ...
    Anyone had such a problem?
  • #2 16734516
    mietek654
    Help: 140
    Rate: 292
    hello give photo as mounted.
  • #3 16736017
    Leon444
    Help: 48
    Rate: 355
    It is mounted in the original place provided for this: Air draft regulator for SAS furnace Damaged Afriso FR1 once again Air draft regulator for SAS furnace Damaged Afriso FR1 once again Air draft regulator for SAS furnace Damaged Afriso FR1 once again
    Today I undressed it and lubricated WD40 and gave it outside for half an hour, of course I am talking about the push cartridge itself.
    I folded it and it works, but somehow so slowly and reluctantly ...
    I do not know myself, I am surprised that for the second time the same at the same time of year (i.e. at the start of the heating season)
  • #4 16737404
    BILGO
    Help: 393
    Rate: 725
    Show pictures how the chain is routed and how it is attached to the door. If the meter works, then there is no problem with raising the flap?
  • #5 16738451
    Leon444
    Help: 48
    Rate: 355
    Tomorrow I will make pics, but at the bottom is on the original flap hook, as the regulator works normally it raises and lowers without any problem ...
    Check for air leaks under the regulator
    #6 16738769
    kolys
    Help: 38
    Rate: 56
    Be sure to take a photo of the flip so that you can see how the chain is mounted.
    Check that the pipe under the regulator is not aerated. When the ruler does not work properly, soak the thread of the ruler and hemp with water and slowly unscrew the ruler with a wrench. Watch if air bubbles or water come out. This is very important because just that a small amount of air or steam gets under the regulator, it stops responding to temperature changes.
  • #7 16738797
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Make a counter weight. The regulator will lower the flap with less force.
    BILGO
    Help: 393
    Rate: 725
    The spring picks up the flap. If it does not close as described above, air / steam under the regulator or stuck somewhere. Everything to check. Maybe the meter is at the wrong angle and there are some forces that wedge the arm?
  • #9 16742616
    Leon444
    Help: 48
    Rate: 355
    Subject to close.
    The reason is the accumulation of air under the regulator, probably not the factory the best place the manufacturer has chosen to place the regulator and with time the air accumulates under it, which disrupts its work ...
    I unscrewed it a little, the air escaped and then water started to flow out ...
    Now it works ok :)
  • #10 16742644
    BILGO
    Help: 393
    Rate: 725
    Exactly, an automatic air vent should be built into the meter ;)
  • #11 16742737
    Leon444
    Help: 48
    Rate: 355
    Yes, but there are those with a vent? Rather not?
  • #12 16742740
    BILGO
    Help: 393
    Rate: 725
    The problem is that I haven't encountered such a thing ;) But you can be tempted to modify. DO the bleed needle screw in the existing meter stand :D Or have fun turning the meter from time to time
  • #13 16742796
    kolys
    Help: 38
    Rate: 56
    That's right, boiler manufacturers have made a serious mistake when installing a pipe that is too high for the regulator. In addition to the problem of aeration, this also causes a delayed reaction of the regulator when the temperature drops (hysteresis) because despite the fact that the temperature has long dropped on the boiler, hot water still remains trapped in this vertical tube because there is no way to cool down. But there are several ways to solve the problem of aeration.
    First make sure that the boiler is placed on the floor in the right way. If the pipe for the regulator is at the top of the boiler (as in your case), the front of the boiler must not be higher than the rear. Ideally, the front of the boiler should be tilted 2-3 millimeters lower than the back. Check with a spirit level if possible.
    You can also shorten the pipe for the regulator by a few cm but for this you will need a steel cutting eraser and a threader and this may void the boiler warranty.
    Another way that worked out very well for me is to mount a tee on this pipe and connect the central outlet of the tee to the supply pipe. This pipe will then be used for venting, so it is important that the pipe is tilted in the right direction. An additional advantage of this solution is the water circulation through the tee and this causes the regulator to react faster to temperature changes, especially when the temperature drops because hot water is not trapped under the regulator.
  • #14 16742934
    BILGO
    Help: 393
    Rate: 725
    Cool patents ;) especially with a tee.
  • #15 16922168
    wisienkka
    Hello from what I know for SAS boilers there are 1/2 inch measures and the problem is in the construction of these measures, compared with the 3/4 gauge. With the latter, it is screwed into the water jacket and there is no problem with aeration. link 3/4 https://www.domer.pl >...> regulators, chimney draft regulators link 1/2 inch. https://www.domer.pl/regulator-ciagu-kominowego-miarkownik-powietrza-regulus-1-2-cala.html
  • #16 17401196
    Leon444
    Help: 48
    Rate: 355
    The construction of the boiler turns out to be a problem, once in a while I have to loosen the denominator to release the air accumulated under it ...
The discussion revolves around recurring issues with air draft regulators for SAS wood stoves, specifically the Regulus and Afriso FR1 models. The original Regulus regulator failed after one year, becoming unresponsive to temperature changes. The user replaced it with an Afriso regulator, which initially functioned well but also exhibited similar problems after a year. Suggestions from other users included checking for air accumulation under the regulator, ensuring proper installation, and considering modifications to improve functionality. The user discovered that loosening the regulator allowed trapped air to escape, restoring its operation. The conversation highlights the importance of proper installation and maintenance to prevent air lock issues and improve the performance of these regulators.
TL;DR: If your SAS boiler’s AFRISO/Regulus draft regulator stops reacting, trapped air is the culprit in 9/10 cases; tilt the boiler front 2–3 mm lower and bleed the regulator. “A small amount of air or steam under the regulator stops it responding.” [Elektroda, kolys, post #16738769]
Why it matters: This FAQ helps SAS solid-fuel owners fix non‑responsive air draft regulators quickly, safely, and without yearly replacements.
What’s the most common reason my draft regulator stops working after summer?
Air accumulates beneath the regulator’s sensing element. Even a small pocket prevents temperature changes from reaching the wax capsule, so the flap stays open. Bleed the connection until water, not bubbles, comes out. “A small amount of air or steam under the regulator stops it responding.” [Elektroda, kolys, post #16738769]
How do I bleed the regulator connection safely?
  1. Cool the boiler and stop the pump.
  2. Loosen the regulator’s threaded bulb fitting slowly; let trapped air escape until water flows.
  3. Retighten, wipe dry, and test operation at your setpoint. This restores thermal contact and immediate response. [Elektroda, Leon444, post #16742616]
Why does the failure recur at the start of each heating season?
Stagnant water and minor evaporation create an air pocket during the off‑season. On first heat‑up, the capsule senses air, not water, and fails to move. Annual bleeding before first firing prevents the seasonal “won’t react” scenario. [Elektroda, Leon444, post #17401196]
Does WD‑40 or oiling the cartridge fix a slow regulator?
No. Lubricants can make it feel smoother but won’t restore thermal coupling through air. The unit may work briefly, then slow again until you purge the trapped air from the connection. Prioritize venting over lubrication. [Elektroda, Leon444, post #16736017]
How should the boiler sit to minimize aeration at the regulator port?
Level the appliance so the front is 2–3 mm lower than the back when the regulator port is high. This bias drives bubbles away from the sensor well and improves cooling after heat demand drops. Check with a spirit level. [Elektroda, kolys, post #16742796]
What plumbing change improves reliability without replacing the regulator?
Install a tee on the regulator’s vertical stub and pipe the tee’s center outlet to the supply line. This adds a vent path and creates circulation past the sensor, reducing hysteresis on cooldown and limiting air lock formation. [Elektroda, kolys, post #16742796]
Is a 1/2" SAS regulator more prone to aeration than a 3/4" model?
Yes. On SAS, many 1/2" units sit on a riser above the jacket, which traps air. 3/4" designs screw into the water jacket, keeping the bulb submerged and less prone to aeration. Choose jacket‑mounted when possible. [Elektroda, wisienkka, post #16922168]
What is a mechanical draft regulator (chain thermostat)?
It’s a wax‑capsule thermostat that pulls a chain to open or close the primary air flap. A spring lifts the flap, while the regulator lowers it as temperature rises. Proper chain routing and free flap movement are essential. [Elektroda, BILGO, post #16742607]
How do I verify the chain and flap aren’t the problem?
Inspect chain routing to the lower door hook and confirm the flap moves freely by hand. The spring should raise it; the regulator should lower it smoothly during warm‑up. Photograph the setup if diagnosing online. [Elektroda, BILGO, post #16737404]
Can a counterweight reduce strain on the regulator?
Yes. Adding a small counterweight helps the regulator close the flap with less force, useful if the flap or gasket drags. Keep movement smooth and avoid over‑weighting, which can cause hunting. [Elektroda, Magister_123, post #16738797]
What failure edge‑case should I watch for after venting?
If the regulator still lags on cooldown, the high vertical stub can trap hot water near the bulb, causing hysteresis. Shorten the stub or add the tee‑to‑supply modification to restore rapid response. [Elektroda, kolys, post #16742796]
My regulator didn’t react at a 70°C setpoint and the boiler neared 100°C—what now?
Kill combustion air, then bleed the regulator connection immediately. This classic symptom indicates an air pocket isolating the sensor. Resume operation only after you see a steady water stream and restored movement. [Elektroda, Leon444, post #16734201]
Should I replace the regulator every year when this happens?
No. The devices often work once air is purged. Users reported normal operation after bleeding without replacing AFRISO or Regulus units. Replace only if the capsule shows no motion in water contact. [Elektroda, Leon444, post #16742616]
Is there an automatic vented regulator for SAS?
Users haven’t encountered regulators with built‑in automatic air vents for SAS mounts. Consider adding a bleed screw to the stand or periodically turning and bleeding the meter to release air. [Elektroda, BILGO, post #16742740]
Any quick pre‑season checklist to prevent repeat issues?
Confirm front‑to‑back tilt (2–3 mm lower front), crack the bulb fitting to bleed until water flows, and test flap movement with chain tension set. This 10‑minute routine prevents start‑up failures. [Elektroda, kolys, post #16742796]
