Hello. I am asking for help, I have had a new 2-function stove for several months, the first problem appeared, in the manual it is too low pressure in the system, when I started it for the first time, I had a similar symbol of a bathtub with a small amount of water, an indication of no water ... or air in the system, I unscrewed the vent cap, the air hissed and the problem was over. Now the problem has reappeared, error E10, the cap is not on the vent and the air does not hiss from the vent and the system is still "cold" and this error is blinking. I tried bleeding through the pump and nothing helped. How can I fix it, so far I have cold water. How to fix it?
krzychu455
krzychu455
Rate: 16
