Expanding Kiano SlimNote Mini 10.1 RAM to 2GB or 4GB and Best Linux Distro for Atom Z3735F
Unitra fan 7551 5
  • #1 16738041
    Unitra fan
    Rate: 9
    It is on a promotion in a ladybug for PLN 300 because it will soon be 14.1 plus
    Is it possible to add RAM up to 2GB or 4 GB there, or DDR3 frames from ordinary laptops will fit?
    I am a Linux lover, what would you recommend, e.g. Lubuntu, Zorin OS Lite or something else.
    Kiano SlimNote mini 10.1
    Intel(R) Atom(R) Z3735F processor 1.33 - 1.83 GHz
    Number of processor cores 4
    2 MB CACHE cache
    10.1 '' screen, 1024 x 600 pixels
    I know you say it's trash, but small and cool.
  • #2 16738192
    sosarek
    Help: 9318
    Rate: 15512
    Yes, but not.
    Z
    Pka, Poznań, 60-850
  • #3 16739481
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    No, since you know better, don't ask in the forum. The equipment is not suitable for comfortable internet browsing, you would have to cut windows10 heavily, besides, the built-in MMC memory may behave differently if you want to use linux.
    You will not add memory because it is soldered into the motherboard, i.e. the main board.
  • #4 16739555
    safbot1st
    Help: 2719
    Rate: 1583
    From what you will find in our forum elektroda.pl these "netbooks" have a terrible Wi-Fi, which works only half a meter from the antenna. In addition, there is no other way to connect to the internet.
    It is mainly for this reason that we strongly advise against, unless you want to browse the facebook with a router on your lap next to Kiano.
  • #5 16784347
    kuba14git
    Rate: 34
    I recommend Slimnote 14.X but to10.1 has a resolution of 1024 by 600, i.e. laughter in the room.
  • #6 19058266
    tivadar.buzasi
    It is possible to reinstall Windows on Kiano SlimNote 10.1. by using a 32-bit version of Windows and the GPT partition. It can be done by using the RUFUS software. It is also possible to install some versions of the Linux (mostly Debian-based ones) with any partitioning by using any application, for example the MX Linux. The laptop works much better with Linux. I am using the laptop to watch TV news on internet and to listen Youtube music and it works fine.
