[Solved] Kiano Slimnote 14.1 - Installing Windows 10 x64 on Intel Atom Z3735F Processor & Recovery Issues
Borygo123 11877 2
  • #1 17251117
    Borygo123
    Help: 121
    Rate: 193
    I have the invention of Kiano Slimnote 14.1 on which someone installed Windows 10 32 bit. I want to return to 64bit, but of course everything goes uphill. Factory reset does not work (from both the system and recovery disk). Data on recovery partitions has not been deleted, but the system cannot use them. I downloaded W10 x32 and it installed without a problem, but when I try to install W10 x64 I get a message about the incompatibility of the processor with x64 architecture
    Intel Atom Z3735F 64 bit processor
    https://ark.intel.com/en/products/80274/Intel-Atom-Processor-Z3735F-2M-Cache-up-to-1_83-GHz
    Kiano Slimnote 14.1 - Installing Windows 10 x64 on Intel Atom Z3735F Processor & Recovery Issues Kiano Slimnote 14.1 - Installing Windows 10 x64 on Intel Atom Z3735F Processor & Recovery Issues
    How can you force this invention to install a 64 bit system. Maybe there is a way to install what is on the recovery partition (size about 1GB).
  • #2 17252770
    199MichalXD
    Contact someone from Kiano.
    It is possible that it is a specially prepared system for such inefficient laptops with an atom.
    A better choice would be windows 7 64 bit
  • #3 17261742
    Borygo123
    Help: 121
    Rate: 193
    For posterity.
    I contacted Kiano service and found out that W10 x64 was installed on this invention, but dedicated to it. They don't share the image, but they have a reinstall system service. I stayed with the 32bit version.
