Kiano Slimnote 14.1 Review: Intel Atom Z3735F, 2GB RAM, 32GB SSD - Suitable for Office Work?
nomadpl 7281 8
  • #1 16223497
    nomadpl
    Rate: 30
    I have a question for you ... I noticed that the little-known to me and most Kiano company introduced Slimnote 14.1 with a half-matrix matrix, Intel Atom processor and 2GB Ram ... + Win10. What do you think about this laptop? Will it be suitable for internet or office work? The previous laptop was with Core2Duo 2.40GHz also 2GB Ram. What do you think is a big gap between them? Can you connect an HDD to it in your pocket? Because the built-in memory is only 32GB + SD extension. What does the installation of programs look like? can you only from the Windows store or just like in a regular lapku / pc?
    Its parameters:
    Processor: Intel Atom Z3735F (4 cores, from 1.33 GHz to 1.83 GHz, 2MB cache)
    Memory: 2 GB (SO-DIMM DDR3, 1600 MHz)
    Disk: 32 GB SSD eMMC
    Graphics: Intel HD Graphics
    I will be grateful for your help.
  • #2 16223675
    KrzysziuN
    Help: 6
    Rate: 78
    So for browsing the internet, what is your budget? Maybe we can rent something better
  • #3 16247845
    nomadpl
    Rate: 30
    Can it be connected to an external USB drive? (I do not mean hdd in my pocket) I asked the kiano hotline and they did not know ... they said it depends on the manufacturer or the disk must have external power supply. The laptop does not have USB 3.0 but has 2.0 ports.
  • #4 16247860
    Kasek21
    Help: 4977
    Rate: 3543
    You buy a used laptop with i3 for as little or no more
  • #5 16247864
    nomadpl
    Rate: 30
    I do not want used ... I am only interested in this model and I do not know what about the USB drive
  • #6 16401038
    cz0p
    The bright disk you plug in will not go crazy with the speed of reading and writing data. I saw that it will be in Biedronka from April 10 for PLN 599, so the mega price is attractive even if it is not perfect. Here you have more extensive reviews of this equipment: http://www.instalki.pl/testy/hardware/25935-kiano-slimnote-14-1-biedronka.html
  • #7 16401072
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    You've got a few reviews on yt. Sometimes I watch the Mobzilla channel, where the guest mainly reviews smartphones, but this Kiano SlimNote also appeared on this channel:
    https://www.youtube.com/watch?v=pHyeoAphpu0
  • #8 16401339
    dt1
    Admin of Computers group
    Help: 7300
    Rate: 8260
    As for the Kiano company, I do not recommend it very much. I don't know if anything has changed, but I bought a tablet for a friend a long time ago. Decent parameters, good price. After half a year, the screen got off (non-mechanical damage, covered by the warranty). After 2 weeks, the tablet was sent back, it worked for another two weeks, and the screen began to peel off the housing. Service again. He came back without sound (at this point I found somewhere assurance that after the service the equipment is thoroughly tested, so I tried to get information on what their thorough tests look like, since they send a tablet to the client where the audio does not work - but this is the question of no working person she couldn't answer me in the company). The headphone jack worked, probably a detail in the form of a non-attached tape, but I did not want to search ... Service :) The tablet came back and ... Surprise, everything worked :) After a month, the microUSB socket collapsed. Service, the tablet came back, two weeks later the socket fell again (and here I can honestly say that the girl using this equipment treated him gently like an egg, was in an armored leather case, connecting the plugs also rather gently and correctly).
    To sum up - the equipment was nice and at a good price, the performance in its price class was quite cool. When it comes to the quality of maintenance services ... I prefer not to write because I don't think so :) When it comes to contacting the company - not the best. After a few sharper exchanges, I managed to get a direct phone call, it seems to the service manager, which slightly improved the situation (I remember that it was only with this man that he could reasonably talk).
    I would prefer, however, some decent post-lease equipment, for which you can often get a 12 month warranty, than a tablet, which in comparison to such a laptop will have rather limited capabilities. As for the Kiano brand itself - if it has improved something over the last two years, maybe it is not a bad equipment, unfortunately for me this company's equipment only because of one equipment, the only one that passed through my hands (actually the service of this equipment) very small a chance to buy again.
    Apart from my dislike of the brand itself - on Atom with Windows 10 you have nothing to count on luxury, this is not a particularly efficient processor. I would even be able to venture to say that a large part of the tasks would have a chance to perform faster on the latest high Core 2 Duo models. The EMMC disk is unlikely to be particularly efficient (it should not be confused with SSDs), 32GB is definitely not enough on Windows 10 (the bare system at the start is probably about 20GB, several updates and the flash is filling up). In general, I would not treat this equipment as a laptop. A more correct comparison would be an average tablet in a case than a laptop with a slightly larger display.
  • #9 16404733
    zen3x
    Help: 231
    Rate: 291
    A shoddy, heavy, hardly functional piece of plastic. Imitating a laptop. The curiosity is the lack of a lan connector is only a wifi network card. soldered on a disc, two usb 2.0 ports and a hard disk based on the type of sd card, quality camera, God bless you. It's good that I talked my friend into buying this "G". For 600 PLN you can have a stimulant, but it is much better than quality and possibilities, for example:
    http://allegro.pl/lenovo-e330-i3-2370m-8gb-160gb-13-cali-bat-3h-i6778463024.html
    http://allegro.pl/laptop-lenovo-t420-i5-2-50ghz-4gb-windows-7-kamera-i6656726104.html
✨ The Kiano Slimnote 14.1, equipped with an Intel Atom Z3735F processor, 2GB RAM, and a 32GB SSD, is under scrutiny for its suitability for internet and office tasks. Users express concerns about its performance compared to older laptops with Core2Duo processors. The device features USB 2.0 ports but lacks USB 3.0, raising questions about external storage connectivity, particularly regarding the use of external USB drives. Some users report negative experiences with Kiano products, citing issues with build quality and customer service. Despite its low price point of PLN 599, opinions vary on its overall value and functionality, with suggestions to consider alternatives like used laptops with better specifications.
