Audi A4 B7 2.0 TDI BPW Engine: Max Oil Pressure, Warm Engine, 2k RPM & Turbo Oil Exhaust Issue
Mroziu88 19284 4
  • #1 16744137
    Mroziu88
    Rate: 31
    I have a question what is the upper limit of oil pressure in 2.0 bpw engine? With the engine warmed up and 2 thousand. revs the car has about 4.5 bar. I ask because the car was made of turbo oil went to the exhaust, not the collector. I know that min. abroad, and max?
    best regards
  • #2 16744155
    szymitsu21
    Help: 343
    Rate: 1300
    It cannot exceed 7 bar high and at 2000rpm a minimum of 4 bar is to be stable, as I remember correctly.
  • #3 16744168
    Mroziu88
    Rate: 31
    Just books say 2 thousand rpm 2 bars
  • Oil pump overflow valve check during pressure test
    #4 16744400
    masay1
    Help: 40
    Rate: 81
    data from Elsa ... for 2.0 TDI; BPW
    checking conditions for oil pressure;
    - the oil level is correct
    - engine oil temperature approx. 80 degrees
    idle oil pressure: min. 0.8 bar
    oil pressure at 2000 rpm. : min. 2.0 bar
    service program Nothing about max. oil pressure, however
    it is worth checking during oil pressure measurement whether it is noticeable
    the moment of opening the oil pump "overflow" valve ... if such a "moment" can be
    notice this indicates that the "overflow" valve is working correctly
    in short; oil pump Ok ... of course provided the required requirements are met
    min. oil pressures at individual engine revolutions, as listed above ...
  • #5 16818759
    Mroziu88
    Rate: 31
    Thank you for the info
